Temp monitoring
478 Views 11 Replies 5 Participants Last post by  ENTERPRISE
Hi there guys can you reccomend any software out there that monitors the temps of my GPU
Thanks guys.
1 - 12 of 12 Posts
Everest home works good for me.
Well yeah sound sounds good but i meant just a program for monitoring temps i dont really want to open up that huge application compared to smaller ones that must be out there...Thanks anyway though
what about the omega drivers, they do the job well.
Hmmm well i have just installed the ATI drivers and im going to stick with them until a new version is out then i will go Omega but there must be a small gpu temp utility program out there.
Ati Tray Tools
Temperature monitoring
Monitoring Graphs. (GPU/Env temperature. GPU/Mem speed, Main CPU Usage).
Originally Posted by z_one
Ati Tray Tools
OH CHEERS MATE just one more question ive installed it and such but where do i go now ive looked about but i must be blind or something because i cant find the GPU monitor bit.
Hmmm well ive found where to monitror gpu temps but its greyed out which must mean i dont have an onboard temp monitor.
Not sure because I have never used it since I don't own an ATI card
But according to Guru3D.com it should be in there somewhere.
Could also try ATI Tool. Also at techpowerup.com
This is odd i cant seem to get the temp monitor working so im geussing my g-card doenst have a temp monitor..When i thought it would as seeing the cards not exactly old lol.
1 - 12 of 12 Posts
