1 - 10 of 10 Posts
When my CPU is at stock settings during the Prime95 torture test(blend)
the temps reach up to ~60 degrees celcius.
is there a reason why this is happening?
my CPU has arctic silver and a Zalman CNPS 7700-CU to cool it, yet is goes over .
Did you ever flash to a newer bios when you first got the motherboard?
yea my bio is up to date
Hmm did you put to much or to little as5 on?And also where are you getting these reading from?
Discussion Starter #5
im pretty sure i put enough. but could that make that much of a difference? at idle for stock my comp is at 33 deg. celc.
Yea I don't think it would make that much of a diffrence if your idle temp is 33.What's the temp in your bios reading?
Discussion Starter #7
im using the program included with my motherboard. uGuru ABIT EQ. thats where im getting my temp from
Hmm I see, I guess try reseating heatsink I'm kind of out of ideals. Sorry.
1 - 10 of 10 Posts
