Temp question on quads?
493 Views 14 Replies 9 Participants Last post by  dralb
Ive seen a lot of odd temps across the quad cores especially mine.
I start out with cores 0 2 at about 30c while core 1 3 is at 39c. In stress testing it all evens out to about a 2c difference between cores.
Why is this?
Thanks much
Sims
1 - 15 of 15 Posts
The amount of load across all 4 cores isn't constant until the machine is put under load and maxes out all 4 cores.
If you are still concerned you can replace the thermal paste and reseat your H/S to make sure, but i'm 99% sure that is what is causing it.
Cheers
Comps
Is it because of which way i have the heat sink? pipes on one side = lower temps
Cheers
Comps
i reseated and applied the paste perfectly so i think its because of the direction of the pipes
most of these q9650's have stuck sensors.my last one had idle temps like this
26-16-36-36, sensors 1,3,4 were stuck at 26-36-36 because i used chilled water
my temps were below 16c.if i put a light load,say super Pi 32m which puts about
50% load, temps would rise to 27c-27c-36c-36c.thats because at 50% load it did
not raise the temps above 27c.once i put 100% load temps all raise to about 50c
to 60c.both my Q9650's had the and so did my E8400/E8500's.
All quads will have different core temps, partially from windows distributing the load. The other problem is the cpu hsf and your cooler may have a slight concave or convex to it. This has happened with my last q6700 and my current i7 (sig). The best way is to lap your cpu and cooler.
That would seem quite feasible, mine was more of an educated guess. (or not so educated if the case may be)
I agree with the others,this isn't all that unusual.Normally for me cores 0,1,2 are about the same(maybe 1 to 2 degree difference)while 3 will differ 2 to 5 degrees.Stressing pulls them all within each other,I wouldn't worry about too much.
Don't sweat it, and don't worry about idle temps. Load temps are what matter, and at that point even if you have a stuck sensor, it wouldn't be under load.
As for your cpu cooler, it isn't the greatest, but how is it working for you?
Originally Posted by reezin14
I agree with the others,this isn't all that unusual.Normally for me cores 0,1,2 are about the same while 3 will differ 2 to 5 degrees.Stressing pulls them all within each other,I wouldn't worry about too much.
so i should worry a little
Thanks all.
Nope, that doesn't even have to anything with it. I own several CPU's and some of them have core differences up to 10c at idle. Heatsink didn't even matter (tried it). The surface of the CPU can be a little uneven.
surprisingly well. I got 4ghz and my max temps under 100% load are 61c with this little 80mm gigabyte cooler
Idle temps are not accurate readings, so there will be huge fluctuations. The sensors are only designed to identify load temps, thus as long as your CPU is within the safe temperatures, then it is fine.
thanks all.
lol.
As others have said, it is normal. Between the software and quality control, they are not perfect. Idle temps don't matter anyways.
1 - 15 of 15 Posts
