1 - 5 of 5 Posts
Originally Posted by AkXb70
yes, but its not as heavy a load as FAH or prime95 will put on the cpu
if your chip is a willamette, it should be good till 60C
Does prime95 even work? lol.. I went to torture test, and selected blended, and 3 minutes in I check my temps.. Still the same as when I browse the internet.. I check cpu usage, buoncing from 15-30%.....
edit: nevermind, I did the "heat test" now =P 100% usage
1 - 5 of 5 Posts
