1 - 3 of 3 Posts
Is there anyway to check if your mobo temp sensors are accurate? Without installing another temp sensing device like the Hardcano 12? Also my motherboard temp sensor varies wildly (+/- 3 Celsius) in between its updates in MBM5. Whats going on?
You can get a Compunurse, or other external probe, but aside from that, there's really no way. BIOS, as well as all Windows programs, all read off the same sensors, so they're all going to report the same. In MBM5, you can adjust the intervals at which it takes a reading. I personally have it set to once a second.
1 - 3 of 3 Posts
