1 - 15 of 15 Posts
I have not even touched vcore or vdimm !<br />
At stock idle was around 28-33<br />
Am i doing something wrong?<br />
<br />
<a href="http://img113.imageshack.us/my.php?image=wowvg1.jpg" target="_blank">http://img113.imageshack.us/my.php?image=wowvg1.jpg</a>
thats dangerously high i suggest you shut down and reseat Heatsink
Can you see a reason why?<br />
It's a little bit hot in my room.. but nothing drastik
Filthy Casual
The heat in your room is probably from your crazy temp inside the PC. Like he said, try reseating your heatsink.
Reseat the heasink using Arctic Silver 5. And make sure its seated correctly and is tight on the mobo. Also check to insure the fan is working properly.
Wait a sec....<img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" /> <br />
<br />
28-33<b><u>C</u></b> ???... if so, then that seems fairly normal to me.<br />
<br />
Perhaps I'm wacky, but my idle is anywehere from 34-44C, depending on the ambient temp. System is Rock Solid stable. Never a hitch, glitch or hiccup.<br />
<br />
...jeez, hope I didn't just jinx myself <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" />
first off those temps idle stock are fine <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /><br />
<br />
second. i found that using TAT to produce full load produces abnormal high temps compared to using TAT just for temp monitor and using dual prime <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /> try that and watch ur temps drop! <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
Discussion Starter #8
When i reseated i noticed that one of the clamps/clips had slipped out ..<br />
And on that note in i had VCore set to auto - and it was at like 1.44V :|
Whoa . . . if that's high, my systems must be really cooking. My desktop runs around 38C on idle. I use SpeedFan to bring it down while I'm playing BF2; all my fans maxed out bring down the idle temp down to 36C.<br />
<br />
My laptop heatsink fan decided to succumb to a software conflict between XP and the Sony program. Poor little P3 800 got up to almost 60C! Finally fixed it and got the temps back under control.
ic.<br />
<br />
also u could try lowering ur ambient... i just switched rooms with my tower. and my idle temps are now 21-23C!!! ambient means everything!!! <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /><br />
<br />
thats about as high as id go with any temps even sub zero... dont wana shorten its life <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /><br />
<br />
for more info on my temps visit my thread <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> <a href="http://www.overclock.net/intel-build-logs/123117-project-perfection-looking-recomendations-10.html" target="_blank">http://www.overclock.net/intel-build...ations-10.html</a> currently the last post <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" />
I remember when......
<tr>
<div>
Originally Posted by <strong>saxdr</strong>
</div>
<div style="font-style:italic">Whoa . . . if that's high, my systems must be really cooking. My desktop runs around 38C on idle. I use SpeedFan to bring it down while I'm playing BF2; all my fans maxed out bring down the idle temp down to 36C.</div>
</td>
</tr>
</table>
</div>Idle temps are almost meaningless (unless your idle temps are 60c <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /> )....it's load temps you want to watch.......you could idle at 38c and full load at 53c and that would still be in spec for a E6300..........Mystikx's load temps were in the 70s.....not good for the CPU he is using.<br />
<br />
Mystikx, see why you should never leave vCore on AUTO when changing other settings <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /><br />
<br />
Glad you got it worked out <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
Reactions: saxdr
a lot of people haven't realized what he's talking about. Click on his picture. It's not the idle temps he's worried about, it's the load ones he's having problems w/. If you look at the pic, his load temps are 70-72 after 1M pi
Hes talking about the picture in his SS guys... <br />
<br />
Anyways, it seems your using Intel's TAT to measure your temps and TAT shows the temp of the actual core rather then the sensor on the side for the Athlons and P4 so the temp will be much higher, your safe under 85C TAT temp from what iv heard <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
<tr>
<div>
Originally Posted by <strong>JacKz5o</strong>
<a href="showthread.php?s=fb118d83aa0ea05832d812d721028acf&p=1376849#post1376849" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Anyways, it seems your using Intel's TAT to measure your temps and TAT shows the temp of the actual core rather then the sensor on the side for the Athlons and P4 so the temp will be much higher, your safe under 85C TAT temp from what iv heard <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /></div>
</td>
</tr>
</table>
</div><br />
You've heard wrong <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /><br />
<br />
<br />
Check the link in my sig.... <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
1 - 15 of 15 Posts
