1 - 6 of 6 Posts
If my load temps on 1.65 vcore are only 38C, could it be said that I could bump it to 1.7, as long as my temps maintain under 50-55C? I realize there could be a factor of current running through the chip, and not just heat, so, again, I'm curious. <br />
<br />
I wish I could bump it up maybe .1 at a time, but it goes straight from 1.65 to 1.7
If you need it for stability I say go for it<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /> As long as your temps are'nt high 1.7v probaly won't hurt. It all kind of depends on your stepping. I'm sure it won't hurt.
as long as u keep the voltage reasonable the only thing that can kill a cpu is the temps.. aside from the obvious..<br />
<br />
high temps of 50C + will reduce the cpus life so beware.. but there are people that only want a cpu to work for a year then they will change it... so they run it 55-60C.. i normally dont let the temps go above 45 load.. usually 35 idle..<br />
but this is with a case that has 200Cfm <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" /> and an air HSF
Discussion Starter #4
I guess I'll take a try at it, gonna try and get to 2.9ghz on this venice....I'll duke it out and hopefully have some good results on Friday. Just found out that my build will have to hold off for another few months, due to the holiday season, and the whole court thing. So, Imma overclock this thing, or run it into the ground until I can get my new stuff........or.........<i>justify</i> getting new things early....<img src="/images/smilies/sneaky.gif" border="0" alt="" title="Sneaky" class="inlineimg" />
Just curious, whats the BIOS temp reported at? <br />
Also, I'd check for any BIOS updates, those temps may not be getting reported accurately... seem a bit on the low side for the voltage/FHS factors, just MHO <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
<div>Originally Posted by <strong>The Duke</strong></div>
<div style="font-style:italic;">Just curious, whats the BIOS temp reported at?<br>
Also, I'd check for any BIOS updates, those temps may not be getting reported accurately... seem a bit on the low side for the voltage/FHS factors, just MHO <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"></div>
</td>
</tr></table></div>
<br>
beat me to it lol. try <a href="http://www.xtremesystems.org/forums/showthread.php?t=103638" target="_blank">core temp</a> because those temps are amazingly low at those volts. are you using the stock fan that came on the BT?
Reactions: toad12585
1 - 6 of 6 Posts
