1 - 7 of 7 Posts
I am running a 3510mhz Athlon II x4 ( 35% OC ) Core temp is reporting 35-38idle , and 47-50 load ( prime95 ) after 1 hour .
I did find some other temps TMPIN1 and its reporting temps of 41-45 when PC idle , and 55-60 load . What is tmpin1 ? Is Tmpin 1 the Internal CPU heat sensor , and Coretemp is only showing the socket temp ?
Either way , i think 73c is the max for my cpu . are these temps stable/okay ?
Old dog, old tricks
The other way around. Core temp is the.. well.. Core temperature
TMPIN1 is the socket.
On my rig I also see the socket temp being 10C higher than core temp, other ppl report the opposite. It's wierd
Old dog, old tricks
Originally Posted by darkslayer7;14156796
so i can oc further with this cooler/chip? I am only reaching 55c while prime 95 . So i have like 10 more c room . "goona crank up ht, and voltage :d"
HT?? HT operates best @stock 2000Mhz, don't raise it above that. Also, although you do have some room for OC, don't take it unless you need it
Operating the CPU @its max temp is far from recommended
Old dog, old tricks
Originally Posted by Devilmaypoop;14156861
He mean HT ref clock, FSB in other words.
Oh, that's serious messing up with the terminology
Originally Posted by Darkslayer7;14156796
So i can OC further with this cooler/chip? I am only reaching 55c while Prime 95 . So i have like 10 more C room . "goona crank up HT, and Voltage
yeah, you can push it a little more.(may not worth it --> too high Vcore for a few MHz)
max. core temp for your chip is 71'C
1 - 7 of 7 Posts
