Its warm but its still okay your ambient temp should be pretty good at the moment in the UK. Thats an 83% overclock youve got there. Youre voltage is more than I would like for continuous use
My Vcore is 1.45 in windows, told you this board has bad Vdroop.
1.55v is nothing to worry about, i run 1.65 on my q6600, but with a way bigger rad. then again, any 360 rad should be sufficient for that.
if i were you id try reseating, if that doesnt help, its already running as it should.
Overclock.net
