1 - 6 of 6 Posts
Does anyone know what all the temps are in SpeedFan?<br><br>
It says Temp1; Temp2; Temp3; HD0; Temp1;<br><br>
Why is there two Temp1's? And I figured using SuperPi and ASUS PC Probe that Temp1 is cpu and Temp2 is mobo and HD0 is HDD temp. But what about Temp3 and Temp1(2)? The temps are like this atm:<br><br>
Temp1: 35c (cpu)<br>
Temp2: 34c (mobo)<br>
Temp3: 27c (unknown???)<br>
HD0: 32C (HDD)<br>
Temp1: 40c (unknown???)<br><br>
And no its not a typo its meant to say "Temp1: 40c".<br><br>
ty
One of them is your GPU temp, I'm guessing the one that is 40C, since the GPU is <i>usually</i> the hottest component in a system, especially with a high-end 7 series card. You can use Nvidia Temperature Monitor (in Nvidia Control Panel) to be compare with that temp and see if they are close/same.<br><br>
Don't know what your other "unknown" temperature is <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown">.
First unknown could be case temp?
Discussion Starter #4
Yes it could be case temp as it changes very little, very quickly and is quite low so yes. But the highest one (40c) I dont think is GPU cos I just playd a game and nVidia says its 58c but it still says 40c in SpeedFan <img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused">
I have another temp1 in my speedfan, i could'nt make head nor tale of it so i just unticked it so it did'nt display<img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
1 - 6 of 6 Posts
