My current rig:
Motherboard - MSI b350m
GPU - gtx 1070 8gb
CPU - Ryzen 5 1600 3.2ghz
Cooler - Wraith Spire (Stock)
Memory - G.Skill DDR4-3200 (2 x 8gb)
PSU - Corsair 450W 80+ Bronze ATX
OS - Win 10
So, I had a question about AIDA64 Extreme. After around 30 minutes it was showing my CPU at around 85c while 100% usage on everything. I OC my cpu to 3.7Ghz from 3.4Ghz which CineBench showed a decent performance increase. I was worried that only after 30 minutes that it rose this high or if this is normal? While playing PubG for 2 hours it stayed at only around 64c. As listed above I'm using the Stock cooler which is soon to be replaced. So is 85c a normal temp after the AIDA stress test after only 30 minutes? or given what my cooler is? Thanks.
GPU - gtx 1070 8gb
OS - Win 10
