1 - 7 of 7 Posts
So.... I've started to OC my GPU..... what temps should i stay under...X1800XT, after market cooler Zaldman VF900, so right now i'm at stock vCore and only have about 74C.<br><br>
Secondly, do i just up the voltage a bit then run "Find Max Core" and watch the temps?<br><br>
Thanks,<br>
AE804
whoa...most people say don't go over 80°<br><br>
I'd check to make sure your VF900 is seated good cause I don't think it should be any where near those temps at stock v-core.<br><br>
I believe the card will auto shut down at around 100°
Reactions: ae804
Filthy Casual
I would say keep it under 70C to be safe, but don't freak out until like 80 or 85.
Reactions: ae804
Vid cards are much more resistant to temps than your cpu.<br>
you don't need to worry at all until you hit 90°C or higher. even then you're getting close but not too high<br><br>
To OC people tend to find max memory and core and back off by ~5MHz. If it's stable - push it until it isn't. If it isn't back off until it is
Discussion Starter #6
i don't remember... it's been a while since i put it on. I have about a week off of school and the like where i'm going to dremel and work on modding to hide wires and put my WC in <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"> I'll check the VF900 then....don't have a GPU waterblock yet, so i'll stick w/ the VF till then.<br><br>
Thanks <img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb"> Reps around <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink">
Discussion Starter #7
Ok, replaced the HSF and it's runnin a bit cooler <img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb"> thanks, there was also some dust on it.<br><br>
It has artifacts though <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown"> i'll figure it out though <img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
1 - 7 of 7 Posts
