Originally Posted by gazkilla Just a quick question.What sort of temperature should a graphic card reach before you think about adding extra cooling? |
Originally Posted by gazkilla Considering my specs,what kinda oc do you think i should achieve? I increased it gradually and testing with 3dmark06 and i got it up to 485Mhz & 1180Mhz.I started getting dots on screen so i lowered it down to 480 & 1160 (temp was staying at about 55-60c) which seemed quite stable but then i got the odd freeze on COD2.So i set the settings back to default(400&1000) and i'm still getting the odd freeze. Have i messed my card up?It seems as if every1 else can get their 7800GT 256mb upto 480+ and 1200+ Cheers Gaz |
Originally Posted by gazkilla Cheers Ste, the Delta clock is set at 40 Gaz |
