1 - 3 of 3 Posts
Did some searching. How about this?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119216&cm_re=Cooler_Master_690_II-_-11-119-216-_-Product
Alternatively, this has a larger width, and is cheaper:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
Or will I need a full tower case? Specifically, I'm thinking about the Hyper 212.
Also, for a motherboard, I'm looking at this:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.575883 or http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.576623
Since I don't care about SLI or USB 3.0 or anything like that, I just wanna know if it's going to be just as good for overclocking purposes. As far as I can tell it should be, but then, I'm pretty new at this stuff!
1 - 3 of 3 Posts
