Ive started a new thread for our testing as the list is going to be quite big and run over quite a few weeks. We are going to get hold of as much tubing as we can so we can show the results of all tubing. Got to add im no expert in these matters and i defiantly not scientist ... These results below and just seeing what happens. please take them with a pinch of salt and make up you own conclusions.
tubing has arrived from http://www.specialtech.co.uk we only need a small amount of it to test pic below ill start testing tonight each colour and let you know how it goes.
I wont be commenting on my thoughts as such just showing you pics and information as my comments are invalid
Left is tygon the rest on the right is Primochill we will get other manufacturers tubing as well.
Test No 1 Tygon R3603
Start of testing preliminary results
+ Mayhems Ultra Pure water
+ Silver kill coil
Temp 40c (Not exposed to UV light)
TDS = 0.00
Conductivity = 0.005us
the mixer / Stirer will have no effect on these tests.
Test 1 run for 3 Hours Results
Comparison Photo. Left New Tygon , Right Tygon after 3 hours.
Water TDS = 03.0 (+3 since start of test in 3 Hrs)
Test No 2 Tygon R3603 (flask sanitised before test so no contamination moves across)
Mayhems Ultra Pure water Only
TDS = 0.00
Conductivity = 0.004us
Test 2 run for 3 Hours Results
Comparison Photo. Left New Tygon , Middle Test 1 Tygon (after wiping off plasticizer you can still see its cloudy) , Right Tygon Test 3 hours in ultra pure water.
Water TDS = 00.5 (+0.5 since start of test in 3 Hrs)
Test No 3 Tygon R3603
+ Mayhems X1 Clear Coolant (vegetable extract based + biocide + inhibitors)
TDS = 0.05
Conductivity = 0.03us
Test 3 run for 3 Hours & 5 Hours Results
Picture below 3 hours test show no signs of leaching how ever ramping up the Heat to 45 c and 5 hours showed the leaching. (single eyebrow raised moment)
TDS = 0.07 (after 3 hours) (40c) (thats the above pic) (the below pic is at 45c)
TDS = 0.1 (after 5 hours at 45c) what is interesting is not the time frame but the temp difference seem to induce the process of leaching. Because between 0-3 hours no leaching was present yet at 3-5 Hours with a 5c increase in temp you could actually see the leaching happing and the water turning slightly cloudy. Note TDS is rising do to exposure to CO2 emission not due to plasticizer.
Test No 4 Tygon R3603
+ Unreleased Product Ethylene Glycol based (Pretty close to what some coolants use except ours has a patented technology.)
Temp 40c (Not exposed to UV light) / then 45c
TDS = 0.03
Conductivity = 0.04us
Test 5 run for 3 Hours & 5 Hours Results
Below Tubing after 3 hours at 40c , TDS 0.06
Below Tubing at 5 hours 45c (this is 3 hours at 40c + 2 hours at 45c) Added note - the tubing has deformed a little when going to 45c. The information on Tygon web site say this tubing is rated at 60c .. TDS 0.08
This test is a 1 off to see what happened 8 Hours at 45c, The tubing has become extremely sticky to the touch. All so Noted That there is plasticizer stuck to the side of the glass in small amounts.
Plasticizer stuck to the base of the glass. This is the best pic i can get of it but its defiantly there. This was not seen in any other test so far.
Test No 5 Tygon R3603
+ Unreleased Product Propylene Glycol Based (used widely by many coolant makers)
TDS - 0.04
Tubing after 3 Hours at 40c TDS 0.06
Again at 3 to 5 hours @45c the Tubing has leached like mad into the glass.
Test No 6 Tygon R3603
+ Mayhems Biocide Extreme (Copper Sulphate being the main ingredient) (awaiting stock as its all done at ware house, should arrive in a few days time)
after 3 hours at 40c TDS not recoded
after 2 hours at 45c TDS not recoded
Test No 7 Tygon R3603
+ Halfords DI water (we need to make sure that our ultra pure isn't the cause of the issue so introducing Other makers DI gives good compassion to make these tests none bias) (need to buy some in)
TDS = 0.6
3 Hours test at 40c, TDS 0.062
After 3-5 Hour test at 45c , TDS 0.066
Test No 8 Tygon R3603
+Exposed directly to UV C light in a water chamber 100 watt light
Tested for 1 hour only (enough time to give a human sunburn badly)
Test 8, 1 hour Results
No change what so ever
Test No 9 Tygon R3603
+Mayhems Pastel Ice White
TDS - 0.04
*** Before we start this test we know we have had lots of trouble with primochill and Tygon tubing so we do not expect this to go well....
Better than expected at 40c for 3 hours - TDS 0.07
3 to 5 Hours at 45c TDS 0.1 Note : the white liquid has a slight tinge of brown to it now. it cannot be seen in photos how ever it is noticeable.
Conclusion for Tygon R3603
PDF for Tygon R-3603 -
FT-Tygon-R3603.pdf 220k .pdf file
There is a noticeable difference when the temp goes from 40c to 45c.
So far not one single product added to the tests shows any difference if that be premix or additive. The tubing seems to be the problem and the fact that if we go from above 40c+ we see it happening a lot faster.
These tests do not prove much except that at a certain temp over a short period of time it easily clouds and start the leaching process. How ever we need to run the same tests on other tubing to see if there is any tubing out there that can do a better job or is it all the same !!!!
Testing complete on Tygon R3603
+ Silver kill coil
TDS = 0.00
TDS = 0.00
TDS = 0.05
TDS = 0.03
TDS - 0.04
TDS = 0.6
TDS - 0.04
