1 - 5 of 5 Posts
With the Skylake cpus not shipping with a stock hewtsink how is everyone testing their set up before water cooling loop is applied?
I have an unopened Thermalright Silver arrow SB-e sitting around but with all the bent pins problems I read about I am worried about installing such a heavy cooler Not opposed to buying something to test with.
What do you smart people of the forums recommend for testing my set up?
Thanks for your time.
PS. If the Thermalright will work can I just set it on top (not bracket it down) just to make sure the set up work?
VROOM VROOM
Lay the computer on its side and install the silver arrow on it.
Shouldn't be an issue that way, or get a different cooler for testing.
1 - 5 of 5 Posts
