1 - 10 of 10 Posts
I have a 2.8 Northwood P4 and want to get rid of the stock heatsink and fan for better overclocking. If anyone knows a good one to use it would be greatly appriciated.
2.8 P4
D865perl
2x512 Kingston pc-3200
Geforce 6600GT
Gamer M1 Mge case
420 psu
40 gig WD 7200 RPM
2.8 P4
D865perl
Geforce 6600GT
Gamer M1 Mge case
420 psu
40 gig WD 7200 RPM
ok, what's your budget? i can help you out better if i have an idea of what your budget is.
Money is not really a factor. Anything that will make it easy to overclock it.
ok, the singlemost best hs fan combo is the thermaltake tower 112 adn two vantec tornados... cheapest parts are rite here:
Tower 112: http://www.zipzoomfly.com/jsp/Produc...uctCode=370491
Vantec tornado (you'll want two of these to get the max effect): http://www.newegg.com/app/ViewProduc...999-612&depa=0
those two coupled together equal a very powerful air cooling solution... i'm sitting in front of a tower 112 rite now that's just about ready to be slapped onto my new comp, and it's heavy, but as long as you support it, it will be fine.
Hope this helps,
ATVkid1090
the
thermalright XP-90 or XP-120 are some of the best HSF
the Thermaltake Tower112 is one of the best also
i have the Tower112 and it cools my prescott really well...
umm judging by your name i guess you smoke...
well my Friend smokes and her computer gets clogged with some wierd dust/tar
and it cloggs all her fans so be prepared to clean them out alot...
oh yeah and its almost 420
410 arizona time
tt tower 112 = pure copper
XP- 90 or 120 = pure aluminum
Copper has a better thermal conductivity
Originally Posted by spookedjunglist
the
410 arizona time
Originally Posted by aznchowboy650
but a factor is that is the weight issue if you can somehome connect the tt tower 112 to the case then it would decrease the amount of weight the board has to hold up
or zip ties...oh gotta love them zip ties
I have the TT silent Tower.... It installed fine and does not seem to put too much stress on the mobo... It comes with a brace that installs on the back side..... What the heck it's only just over a pound... and about 5 inches tall...
It works great and is very quiet...
yea, what's yours made of? if it's something other than copper, it prolly is liek aluminum alloy or something... but this ones like heavy..adn i mean heeavy
1 - 10 of 10 Posts
