Okay so I need a 120mm pwm fan that is best for rads and this is going to have some requirements below and reasons.
Requirements
1. They have to be PWM I need 23 of them and there going to need to be controlled by either the mobo header and split or by the new corsair link system I'm not going to run bay controllers it happening so throw that out right now They have to be PWM period.
2. Quite at low RPMS as quite as possible at high RPMS The will all be ran as low as possible most of the time then at high loads benching ect half will need to ramp up to at least 2k rpm. (the other half will be on thin rads and can stay at 1500 or so)
3. Must have a max speed of at least 2k rpms. ( I guess 1850 would be alright but prefer 2k or higher)
4. The must be black or at the very least have black blades and no non black rubber ect that cant be not removed without affecting anything as they need to be all black or be able to be made all black without modding blades.
Preferences
Have an aggressive look to them.
Have a 140mm similar looking counterpart doesnt have to be good for rads as it will be only 1 140mm and it will be as exhaust not as a rad fan.
Okay shoot throw some at me
15 dollars or less (however more is fine this is just preferred)
Edit: Has anyone used or seen any reviews for the bitfenix spectre pros pwm as they check all the boxes good for rads. Obv they aren't as good as gentle typhoons but i need exact requirements even at a slight loss of cooling. I am even switching to the red team so that i can get black edition cards for my black out build so it has to be black that is not going to be budged on and the grey on typhoons and corsairs ait going to work( the visible ones at least I currently have some corsair QE and they will stay on my st30 480 as in the 900d that's not visible with a midplate. But for all internal and visible fans I need something black and aggresive.
My loop is already going to be overkill with 4 rads so squeezing every ounce isn't really needed.
Requirements
Preferences
