The best Video card for that rig
616 Views 13 Replies 12 Participants Last post by  elson
Hello, I'm trying to get the best choice for my friend's computer
that is his rig:
Motherboard NameAsus P5SD2-VM
DIMM2: Kingston (2 GB DDR2-667 DDR2 SDRAM)
CPU TypeDualCore Intel Core 2 Duo E4600, 2400 MHz (12 x 200) (not overclocked and I'm not going to be overclocking it on this ***** board.)
PSU: some crappy generic 400W psu
+12V - 19A
+5V - 28A
-12V - 0.8A
-5V - 0.5A
He ain't going to play on that computer the best games, I thought something like NFS carbon/ COD4 / MW2/ mirrors edge / and that kind of games.
At the moment I am in Mexico city, So I have no problem to order it from U.S
Gracias
1 - 14 of 14 Posts
I recommend the evga 7300 gt, its cheap and it plays all of those at max or close to max. Just make sure you get the ddr3 version.
Sorry I didn't realize this was the ATI section
Still, it's a good card.
I'd suggest a 8800GT/9800GT. Awesome card for a budget price. And it wouldn't be too overpowering for that rig to handle.
I used a 4850 on a PSU with similar specs with no issue. Granted it's kind of risky, but it could work.
But a 4650 for 37.99 after MIR http://www.newegg.com/Product/Produc...82E16814131178 Could also work
I suggest an 8800GT or 9800GT. Maybe even a 4650 or 4670
What resolution does your friend play at? There is a big difference maxing out 1280x1024 vs 1920x1200.
I would disagree, I would recommend something alot more powerful than that.
Given his powersupply, I would probably recommend a 4770 or 5750.
I think some other upgrades are in order before you even THINK about a new video card
More ram and a new psu for starters
That aside, a 4670 would probably work
I would say that a HD4770 would be good from the ATI side. An 8800GT would be great as well. Not much more than that on a generic PSU.
I have a rig with a 8800GT and a E4700, and even on stock clocks I can run COD4 and COD [email protected] maxed out at 1080p.
2gb of ram is fine for the moment. None of the games listed will require more than 2gb.
He has FLATRON L192WS screen, I guess he will play at the max resolution available. which is 1440X900 if i'm not wrong.
Let's say i go with 8800GT.
Which is the best of them? the brands I mean.
Something cheap, powerful, and cool(with fine htf)
Any budget on the card? Only reason I ask is b/c the 57xxx series are extremely efficient and would provide excellent performance/power consumption: a 5750 might be a great choice for your friend.
^This. Plus you could through in a 4850 if you find one for cheap.
i say 4850, it dropped in price recently very good GPU. if he can push the price limit then 5750.
4770 for ATI. Good performance for cheap price.
9800GT or a used 8800GT will be fine from Nv side.
1 - 14 of 14 Posts
