1 - 20 of 29 Posts
I think it would be beneficial to the sub-forum to have a dedicated thread to case choices. To get suggestions, just post the following form with your answers, and to promote productivity, Please post at least one suggestion to someone else's request.
Please suggest more criteria to add to the list!
Case Criteria
1.) What is your budget? (include buying limitations or benefits such as access to a MicroCenter, international location, or specific websites)
2.) What size case do you want? (measurements or full tower/mid tower...
3.) What Motherboard support do you want?
4.) What materials do you want the case to be made of?
5.) What color(s) do you want the case in?
6.) What motherboard mounting do you want? (ATX, Reverse ATX, 90 degree ATX, Horizontal...)
7.) How many internal/external 5.25", 3.5" and 2.5" drive bays do you want?
8.) Is extreme silence a goal for your build?
9.) How important is cable management?
10.) What cooling support do you want?
11.) What front panel features do you want? (built in USB 3.0, Media card reader, Fast charge, HD Audio, Fan/ led controller, hotswap bay...)
12.) How many PCI expansion slots do you need/want?
13.) Do you want tool-less mounts for your drives?
14.) How large of graphics cards do you want to be supported?
15.) What style of case do you want? (edgy, simplistic...)
16.) How big of a PSU do you need it to hold?
17.) Any other preferences
Hello! I'll kick this thread and my account off with this post XD
MY IDEAL CASE
I have no budget. I have no preference of buying site. I live in Hawaii, so try to choose sites that give various shipping options.
I want a relatively small case. It will be constantly transported. Try to keep the largest dimension around 18 inches. Make it pretty light as well (nothing like the Cosmos II)
It needs to fit e-atx motherboards.
I'd like it to be made of mostly metal, though plastic for accents or a front panel doesn't hurt if it makes the case look nicer and isn't cheap or flimsy.
I can get the case powdercoated, but I'd like it in either red, gold, or white. This is really not an issue.
The type of mount matters not. Whichever one has the best airflow, I guess!
I don't really care about the number of bays. A reasonable number is fine. I usually run two HDDs, two SDDs, and an optical drive isn't needed, but wanted.
No, it is not. I don't want to build a vacuum cleaner, though.
Cable management is super important to me! I sleeve all my cables, and make sure I am happy with the way it looks every time.
Good cooling is a MUST. It gets pretty hot down here. I will probably watercool, but I don't need anything too extreme. One loop for cpu and mobo blocks and one loop for gpu. Space for two 120 mm radiators, or something like that. I don't need the caselabs cases with extreme space =P.
I would like usb 3.0, that would be nice. Space to put a fan controller as well. Anything else is icing on the cake!
Enough for a wifi card (is that the right word?), 2 gpus, and one more extra for anything I decide to put in. That's not a lot.
Tool-less mounts would be convenient, but not a necessity.
A foot would suffice for gpu length.
I would like a case that takes itself seriously. Nothing like a lanboy air or anything with flashy leds everywhere.
So, any suggestions? You can go a little bigger on case size. I can always put casters or handles onto the case.
it's going to be pretty hard finding a case that takes true e-atx motherboards under 18 inches, now if you mean e-atx like the asus RIVE style motherboards, that aren't the full 12 inches wide, that'll make it a good bit easier, but it's still a pretty tall order
· Premium Member
an often missed but occasionally becoming a major issue criteria would be PSU size requirement. this is especially true for SFF enthusiasts.
other less common criteria that may become an issue is GPU height. there are a number of none standard height gpu cooler for passive cooling cards that may not fit in some SFF chassis. this of course applies to CPU cooler too but that criteria is covered under #10
Thanks for the suggestions, added!
Originally Posted by Babbalabba View Post
That is a good point, psyclum. Maybe the OP can add those questions in.
I'm staring to think I need to contact an artisan for a quote, someone like lazerwerx so I can get the case I want.
You could Also try Dwood
I will check Dwood out! Frozenq pc has a mid tower that is 18 by 18 by 9, I will email them to ask about the weight and for more pics. It's all acrylic, and I am thinking that's what I want. Other options include the Nzxt phantom, the Kublai Silverstone series, and the 650D/600T
Discussion Starter · #9 ·
Maybe try the Phantom 630? Or Phantom 410 (mid tower)
· Banned
My budget is anywhere from $ 70 - 250 Australian Dollars
Mid Tower
Atx
Aluminum would be ideal but steel is okay too
Black
Atx only
Up to 4 optical bays, at least 2 ssd mounts, 3.5 - up to 4
No
Quite
Descent Air cooling, 240 mount location would be nice but not necessary
USB 3.0 is all that matters, fast charge would be nice too though
5
Doesnt matter
GTX 680
Simplistic, non gamer, non flashy, subtle
650 - 750q
I cannot stand the look of Gamer cases currently, I think they look awful, and I am not really into windowed side panels. I'd much rather just have a plain looking but subtle & nice pc case and turn it into a powerful pc with some secrets under the hood.
Case Criteria
~$300
Full Tower
RIVE MOBO
Dont care
Black
dont care
at least 2 HD.. space, and 3 external for the reservoir
kinda
VERY!
WATER!!!!
dont care
enough for 2 GTX 680
dont care
GTX 680
not square
CPU Motherboard Graphics RAM
3930k ASUS P9X79 (may change to RIVE Gigabyte GeForce GTX 680 64GB Corsair Vengance 1866MHz
Hard Drive OS Monitor Keyboard
520 180GB x 2 Raid 0 Win 7 64bit 2 x 2410 Mad Catz S.T.R.I.K.E. 7
Power Mouse Mouse Pad Audio
Corsair HX 1050
Want it to be water cooling ready, and that supports at least a 360 rad...
I like the 800D, but wanted to see whats out there before i buy
supermiguel, if you can dig a little deeper into your pocket, the Caselabs sm8 is practically the perfect case. It is light for its size, and can fit a confounding number of radiators. It will make the RIVE look oh so small.
Other than that, the switch 810 is great. I have to applaud NZXT's use of plastic in their cases, it isn't cringe worthy and actually, I feel, adds to the look and brings the price and weight down.
You can look at mid-towers for a more compact solution. For example, many mid-towers can fit the rive, but they jut out/block some grommets, etc.
The 800D is great, but the sm8 is my choice
Aaargh! How do I get rid of a double post?!?!
Discussion Starter · #14 ·
Edit the posts and ask for a mod to delete them
Check out the following:
NZXT Switch 810
NZXT Phantom 820
Bitfenix Colossus
~$100 in the U.S.
Mid tower unless a full will fit in my budget
ATX Mobo
Steel or Aluminum
Black or Gunmetal
Standard ATX
At least 3 5.25 bays and 2 3.5 in bays
Wouldn't hurt but not an necessity.
Most important, I want the least amount of wires showing as possible
I'd like to put a dual 120mm rad in at some point
Not a factor
7 or 8
Yes
Not a factor
Simple yet rugged (Think corsair 300r, etc.)
Just standard size
Window is a must
Mid Tower
Atx
Black
Atx only
No
Quite
5
Doesnt matter
GTX 680
650 - 750q
Corsair Obsidian Series 550D?
Discussion Starter · #17 ·
~$100 in the U.S.
ATX Mobo
Steel or Aluminum
Black or Gunmetal
Standard ATX
Not a factor
7 or 8
Yes
Not a factor
Just standard size
Window is a must
nzxt phantom 410 (not a full window, but a window none the less)
antec eleven hundred (the 240 would have to be mounted internally, but if it's just a slim rad it'll fit no problem
also the currently hard to find fractal design's arc midi r2 has a window version which is supposed to list for $110
Alright thanks guys!
I'm liking the 300r windowed and 500r. How hard is it to see through the 500r's mesh? Also what about a C70? lol It seems like corsair designed all their cases specifically for me
Phantom seems like and awesome case but I'm not really into the external aesthetics.
Discussion Starter · #20 ·
C70 is a good case too
1 - 20 of 29 Posts
