Very nice guide. Pictures would be great, but still, very nice. Thanks for donating your time for the cause. rep+
These are three (two) categories of CPU clients:
●---SMP Client---● Quote:
●---VMWare client---● Quote:
Run these clients if: You have at least one:
1)Download:
3) Customize:
Notes: Important Note #1.1: Do not forget to change the Machine ID for these clients, depending on how many CPU clients you already have running. Important note #1.2: If you are folding on multiple nvidia cards you will have to disable SLI in the nVidia control panel. If folding on multiple ATi cards you can leave CrossFire enabled, under the condition you have the latest graphics drivers. Important note #1.3: Folding on both your CPU and GPU might cause your GPU to run slowly, set the GPU cores' priority using this tool: http://www.overclock.net/overclock-n...tpriority.html 4) Hide:
Make sure one of all the clients is running (If you have multiple GPU clients). Download this little application: http://www.teamcti.com/trayit/trayit.htm Extract it in a folder somewhere in your hard drive, somewhere you won't mind it being for ever (aka: Not your desktop). Run it and right click the client in the window that appears. Select "Place in system tray". Is it hidden down there? Great. Now go to Edit -> Profiles and edit the profile you just created and enable "Minimize on windows creation". Hit OK. Close the "Profiles List" and head to Edit -> Options. Here we will have to make sure the following are enabled:
Notes 2: Important Note #2.1: When gaming while folding on your GPU, your [email protected] GPU client can get unstable. It is recommended that:
Keep in mind that when folding with an ATi card, it using quite a lot of CPU power is normal. Please check this post out. |
You've got your client(s) up and running, but how fast are you? For this purpose, most people use a free, small application called FahMon. Download: Get FahMon here: http://www.fahmon.net/download.html As you can see, there's a Windows Installer and a Windows Zip version available. Both function exactly the same. If you don't know which to choose, get the Windows Installer. Configuration: After installation/extraction, run the program. Go to FahMon -> Preferences -> General tab: Typically, you select everything here. In the next tab, called Monitoring, I suggest the following settings:
Go to Clients->Add a new client. Enter a name for you client and type its location as described:
Want to know what everything you see in FahMon means? Read here: http://trac.fahmon.net/ Its "Table of Contents" contains pretty much everything you will ever need to know. |
If you want to find out more about your point statistics and ranking simply search your folding name here: http://folding.extremeoverclocking.com/ [To be completed] |
Originally Posted by gibsonnova74 ![]() Very nice guide. Pictures would be great, but still, very nice. Thanks for donating your time for the cause. rep+ |
-verbosity x Sets the output level, from 1 to 9 (max). The default is 3. This option should be used if the user wishes to see more detailed client output, particularly useful if there is a problem which needs to be reported to the [email protected] client development team. |
