This question gets asked at least once a day....sometime 2, 3, 4 or more times a day. Using the search button, I understand, is a very demanding task, and it can certainly be frightening for new members...what with it's big scary white letters and sneering pull-down menu.
(okay, maybe I'm over exaggerating, but it does get asked rather frequently, and the answer never changes.
So, here it is, the definitive answer to "Can I overclock my Intel mobo/dell/hp/compaq....?"
Short answer: no. Intel motherboards (which are used by all proprietary system builders, like dell, HP, etc) do not offer the necessary functions for BIOS overclocking. Without such options as CPU and RAM voltage adjustments, FSB adjustability and AGP/PCI bus locks, you will have little to no success.
Long answer: yes....via software. Software like clockgen (www.cpuid.com), cpusoft (now defunct, along with others), or other software utilities (included with motherboards that are intended for use by enthusiasts) may or may not support your Intel/proprietary motherboard, and is generally not very effective.
These are the facts, folks, I'm sorry to say. Hey, if you've successfully overclocked via software, then by all means, please post results as well as make, model, all pertinent system info and software used. At the very least, if some have had success, we can start compiling some information, for those who have not yet had success.
