41 - 55 of 55 Posts
Originally Posted by MunneY View Post
Very Very nice! I really wanted those 780 blocks, but I couldn't make myself get them after I saw the performance.
I just got mine today (2). I saw the review a little to late
They dont do much cooling for the VRAM and VRM but if you dont OC them to much then they are fine. Guess I wont be OC'ing then much.
Originally Posted by xD3aDPooLx View Post
What specs do you want? Maker, size, dimensions?
Dims please. thanks. I was going to order a 60mm. But if I go with this case, it doesnt look like it will fit. Looks more like a 30 or 45 with push or pull only.
Dont know if you know this, but with a 240 in the front, vertical, can you still make use of the drive bays? I would need HDD and optical. and maybe a card reader
Or should I just go with the 810?
Thats my thing... I'm gonna run the 1.3v bios mod.
Originally Posted by Mosquito Mods View Post
Man everyone's hatin' on the purple...
I like the purple, favorite color.
Purple is one of my favorite colors as well, I personally just don't like UV lights.
Discussion Starter · #50 ·
Originally Posted by boogschd View Post
ive always wondered if those white nzxt fans glow under UV light
now, i am dissapoint :|
great build though !
There is some UV reactive paint that you can get called clear neon. Goes on clear and pops under UV light.. I should have ordered some....
ill look into those. thanks
though i suspect id have to get those overseas .. which will probably cost a butt ton in shipping :/
A METRIC butt ton.
41 - 55 of 55 Posts
