1 - 3 of 3 Posts
I've been debating between these two motherboards. Help me choose?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128532R
GIGABYTE
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157284
ASROCK
They have similar specs, but honestly the AsRock has more features, but I need some guidance anyway as this is my first purchase of a high-end motherboard.
If you have a different motherboard you'd like to recommend, keep in mind my budget is $260, I need a board that supports tri-SLI/CF, and has 4 or more 6.0 SATA III ports.
Thanks again guys! You rock.
Originally Posted by MartynRE View Post
I would go with the asrock board, they are always solid and come with a lot of features for the price.
Are they cheap build quality?
1 - 3 of 3 Posts
