1 - 20 of 902 Posts
Decided to make a checklist of all the things that I need/have, and keep myself organized. Worked well with the Phoenix log, so I think I'll give it another shot here!
-Taig CNC-ready Mill- HAVE
-IMService Servo Drivers, kit 4A- HAVE
-PMDX-122 Control Board- HAVE
-3" Screwless Vise- HAVE
-Assortment of endmills- HAVE
-Various tools every machinist needs- HAVE
-Mounting box/plate for PCB's- DONE
Hey Guys,
I finally decided to start a worklog, this will continue throughout the summer. A majority of the time will be spent working to get enough money to actually buy these components, and until then, this log won't see much action.
However, I wanted to throw some stuff out here.
Mill:
http://www.taigtools.com/mmill.html
I did a lot of research into this, I even went to cnczone.com to look at what people had to say because I didn't want something that would break easily after 2 months. The model I am getting is the 2019CR-ER, which comes with the ER16 spindle and is CNC-ready.
Motors, drivers, control board, and CAM (Computer controller) software:
http://www.cadcamcadcam.com/index.as...ROD&ProdID=126
^ Click the 4-axis option, and then reload.
This "kit" comes with everything you need, motors(servoes), cabling, hardware, etc.
Why are servoes better than conventional motors?
When working with machinery, the motor "counts" a series of steps inside the motor so the software knows where the motors are and knows how far and fast to move the motors so the piece gets moved around. When conventional motors accellerate fast, they lose a "step", and that can throw your entire project off, possibly plowing your bit into the side or shifting the entire program one way or another. Also, if metal chips get inside the screws that are driven by the motors and it jams, the motors will still spin, but they'll just spin....A servo reports the sudden stop and lets the computer know what's going on and what happened.
Various other parts:
Solid state relay:
http://www.cadcamcadcam.com/index.as...l=&strCompare=
^ Need one of those to make the kit work.
PSU:
28V DC, 10A
I may need a serial cable:
http://www.newegg.com/Product/Produc...82E16812123083
The Serial-USB converter works nicely, here:
http://www.newegg.com/Product/Produc...E16812149115If this is long enough (6 ft), then I won't need the serial cable above.
Various switches, connetors, etc., I can get these at Home Depot. I need "the big red button" for my emergency-stop (E-stop) switch that halts the entire thing if something goes wrong.
Eventually:
That's the fourth axis that I was talking about above- If I wanted to machine out, say, the contours of a barrel or drill holes into a rifle barrel, I would use this. It rotates the piece using the big thing, and the smaller piece keeps it rotating level.
Obviously a lot of stuff going on here. Post what you think would be cool to do with it, and I'll try to make it happen. Post away!
Will do...This will be a very fun project once things start getting here. Of course, I'll post a ton of pictures.
That motor control kit is expensive! Why don't you get THIS, THIS and THIS? Then you would just have to make a case to put it in.
Reactions: tuchan
I knew you'd ask that.
http://www.imsrv.com/deskcnc/steppers_vs_servos.htm
Explains all. Pretty much, servoes are much more accurate. They split an inch into 110,000 "steps".
Wow, nice call!
It kind of sucks that they are so much more expensive though.
You're right, it most definitely sucks. However, in the long run, these will be better for me, longer life and they retain accuracy.
Discussion Starter · #11 ·
UPDATE! Now that we've lost Shawn
, I am the only one to carry on the mill!
I am ordering it tomorrow- I need to get some money out and the bank is closed.
1-4 weeks to my door, freight is all the way from Oregon to my door.
I'm SO excited!
This Panasonic Lumix is gonna get worked hard once the mill arrives
If you don't mind my asking, what's the price tag on all of this? I really want to get into the CNC game, but the prices are just so high. I end up doing 3D CAD models of stuff I build, then doing it by hand from the picture.
Also, what kind of software do you use with it? I saw the THG article on machining, but they didn't mention specifics on the setup.
Discussion Starter · #13 ·
Well, the Mill is going to cost $1000, the motors will cost $1000, the controller that interfaces the motors with the PC is ~130, and tooling is ~200...It's an expensive game to get into.
I will be using a program called Mach3 from www.artofcnc.ca, it's a free program that controls up to 6 axes of movement.
Discussion Starter · #15 ·
Take down the site link and I will tell you. The URL cannot be posted until I start advertising here.
NICE! I can't wait! I think I am more excited than you are Burn!
Discussion Starter · #17 ·
I am very excited...I need to buy some endmills now...I will have a 3/16" and a 3/8" collet to work with.
3/8" was what I primarily used when I cut the prototypes, that and 1/2". You should be able to find a 7/16" cutter with a 3/8" shank but I don't know how much the motor can handle. Any industrial supply warehouse or shop would have toolbits, I got my aluminum cutters from one and they were high quality, generally you get what you pay for.
It could probably handle a big cutter then.
Especially since you won't be cutting a lot of steel. I am not sure if there are 1/2" cutters with a 3/8 shank, you might be able to find one though.
1 - 20 of 902 Posts
