Well, honestly its been about 3 weeks now and I am still tinkering and Overclocking this board. I am sure there are so many of you out there with this combination that it would be exciting to post your successful overclocks on this thread. I have inserted two pics depicting stable configurations below. I have been told my VID of 1.225 is great.
1.) 3.33 Ghz Stable 7+ hours ORTHOS and MEMTEST. Memory is at a 1:1 Ratio. FSB was set at 1480 in Sync with the memory 740Mhz. 4-4-4-12. vCORE was set at 1.2875 in the BIOS. CPU-Z read 1.25 with vDroop. System voltage at 1.22 upon load.
2.) 3.40 ghz Stable 4+ hours ORTHOS and MEMTEST. Memory is at a 1:1 Ratio FSB was set at 1512 in Sync with memory 756Mhz. 4-4-4-12. vCORE was set at 1.2875 in the BIOS. CPU-Z read 1.25 with vDroop. System voltage at 1.22 upon load.
3.) 3.44 ghz Stable 4+ hours ORTHOS and MEMTEST. Memory is at a 1:1 Ratio FSB was set at 1512 in Sync with memory 766Mhz. 4-4-4-12. vCORE was set at 1.3075 in the BIOS. CPU-Z read 1.26with vDroop. System voltage at 1.24 upon load.
