I open this thread so that all members are able to share their information and discuss GeForce 9 series GPU here. I greatly appreciate your supports.
nVidia is very tight lipped about their new GeForce 9 series GPU in terms 2008 road map as well the product naming scheme and price structure. The specs of GeForce 9 series GPU lists here is unofficial. I will update it as soon as the official data is available.
For all GeForce 9 series GPUs owners, if you would like to share your information, (which I encourage you to do), please provide your information. I will list you in the GeForce 9 series owner's list.
Currently, we don't have a feature that allows multi members maintain a thread. This is very important because we have many members who have exceptional knowledge and great experiences. Their valuable inputs will definitely enrich and make this thread informative. Therefore, I encourage members provide information related to GeForce 9 series GPU and suggestion on how to maintain this thread. You post the information under the main thread. I will create a link pointing to your post under your name. In this way, you have all credits. Viewers can go to your post to view the contents. I encourage viewers give rep to these members if you find their information is helpful. This is the best way for you to appreciate their efforts.
Geforce 9 Series GPU Thread Signature tag
[CODE]
[center][url="http://www.overclock.net/nvidia/277311-geforce-9-series-gpu-info-thread.html"]:bruce:[b]Geforce 9 Series GPU Information Thread[/b][/url][/center]
[/CODE]
To add this to your signature, go to User CP, edit signature, copy the code above, paste there and save.
Table of Contents
- Latest GeForce 9 series GPU Information And Discussion
- GeForce 9 series GPU Owners
- GeForce 9 series GPU Reference Specs
- Retail GeForce 9 series GPU Specs and Manufactuers List
- GeForce 9 series GPU Pictures Gallery
- Reference Benchmark
NVIDIA GPU Roadmap for first half of 2008
NVIDIA GPU Roadmap for first half of 2008 is out. The GeForce 9 series GPU are still using 65nm and won't expect to change until second half of 2008.
- GeForce 9800 GX2 in March timeframe.
- GeForce 9800 GTX in March timeframe. This card will support Tri-SLI.
- GeForce 9800 GT/GS in March / April timeframe.
- GeForce 9600 GT in Feb 14 and will fall in line below the 8800 GT, but give better performance than the GeForce 8600 GTS. Price point will be at $169 in retail. nVidia are planning on carrying this GPU throughout 2008. 9600GT designs to replace 8600GT/GTS. In the intial stage, it claims 90% faster than the GeForce 8600 but will slow than 8800GT/GS.
GeForce 9800 GT salty specs detailed
Details Here.
9800GX2, 9800GTX, 9800GT and HD3870X2
Details Here.
3DMark Vantage : 3870X2 vs 9800GX2
Source
GeForce 9 Owner List
Below is a list of some of the current GeForce 9 owners. If you would like to share the your information, please provide the following information: Owner Name, Manufacturer Name, Model #, Memory Size, Core Clock (stock/OC), Shader Clock (stock/OC), Memory Clock (stock/OC), SLI, GPU HS, GPU Idle Temperature, GPU Load Temp, Processor, CPU Speed, System Memory, Motherboard, 3DMark06 score and OS (operation system).
Please feel free to contact me to change your information.
GeForce 9 Series Pictures Gallery
Featured 9600GT Cards.
Click Here For The Larger Size of 9600GT Images
Retail 9600GT Specs, Manufacturers List
Here is a list of the current 9600GT cards that are available as of today. This list will be updated as more information is released. The default core clock is set at 650 MHz, shader clock at 1625 MHz and memory clock at 900MHz. (Data that is not specified by the manufacturer with be denoted with an * (asterisk).
Retail 9800GX2 Specs, Manufacturers List
Here is a list of the current 9800GX2 cards that are available as of today. This list will be updated as more information is released. The default core clock is set at 600 MHz, shader clock at 1500 MHz and memory clock at 1000MHz.
Make sure you have a good 600W PSU with 40A on 12v rails and one 8 pin PCIE power connector. (Data that is not specified by the manufacturer with be denoted with an * (asterisk).
Retail 9800GTX Specs, Manufacturers List
Here is a list of the current 9800GTX cards that are available as of today. This list will be updated as more information is released. The default core clock is set at 675 MHz, shader clock at 1688 MHz and memory clock at 1100MHz.
Make sure you have a good 450W PSU with 26A on 12v rails. 550W with 32A on 12v rails. Two 6-pin PCIE power connectors. (Data that is not specified by the manufacturer with be denoted with an * (asterisk).
GeForce 9600GT reviews
NVIDIA GeForce 9800 GX2 Reviews
