Hey all
This is a continuation of a previous post that I had made regarding my problems burning DVD video. Well, now I'm once again stumped and would like some help.
The problem:
I go to burn video using DVD shrink because it auto compresses the DVD's to a size where I can re burn them onto DVD-R disks. I tried DVD Decrypter but the files always turned out uncompressed and were too big to burn. Anyways, once I used DVD shrink I would burn the files and everything would seem to work hunky dory. But, every single DVD I have burned (totaling 8 different ones) I have encountered the same problem. The movie plays perfectly for the first half to 2/3rds of the way through. Then it starts skipping and eventually crashes, both on my computer and on the DVD player hooked to the TV. The thing is the original plays good, and the copied files play good on my comp, but once they are burned it craps up. And it never skips in the same place. On one burned copy it would skip at a certain scene, on another copy of the same disk it would skip somewhere else?? Is it my DVD burner or the no name brand DVD-R's I'm using? Or is there some other software that would help me eliminate this problem? I hope it's not my DVD burner cause i burnt these DVD's but didn't watch them all the way through and I figured it worked so I painted the faceplate of the burner and I don't think I can get it RMA'd now.
Thanks in advance
The problem:
Thanks in advance
