Welcome to overclock.net
If you can increase budget by a little...I suggest getting a slightly higher end GPU like a GTX260 or even a GTX275. I'm not sure what GPUs are similar on the ATI side but feel free to check what they have to offer as well.
Another thing I'm looking at is the PSU since I'm not that familiar with Rosewill PSUs. You should check the Power Supply Recommendation thread to see what PSUs are decent. You can also check eXtreme Power Supply Calculator to see how much wattage you may need (add another 100-200watts for headroom
). Just know that you also have to put into consideration AMPS and quality on the PSU when you buy one.
I'm not familiar with the case but it looks good from the looks of it (good price for a full tower). I checked YouTube for a video review on it and it looks decent. People would probably recommend you a Cooler Master case (HAF932/Scout/690/Cosmos/etc) but I'd say go for what ever may fit your needs (plus I don't like having a case that a lot of other people have
). Anyway...feel free to ask for help when you run into any trouble when building your computer. Btw...people with high-end computers are actually a high minority of the population of computer owners and you are going to be one to with that build to
