How to Join..
POST A PICTURE OF YOUR STORM TROOPER AND OR STORM STRYKER AND
FILL OUT THIS FORM FOR MEMBERSHIP
AND YOU ARE DONE.
STAY HONORABLE AND STRONG.
Official OCN Case Club as of 02/07/2012 authorized by kevingreenbmx
On Sale Now $149.00 US MSRP
ONE OF THE BEST CASES FOR UNDER $200.00. BAR NONE.
COMMAND FIRST GENERAL ORDER
IMPORTANT DETERMINE THAT SATA PLUG IS PLUGGED INTO THE TOP CONTROL PANEL BEFORE STARTING BUILD
1. RADIATOR PLACEMENT ON TOP OF THE CASE.
The Exterior is painted Black and the front shows a total of 9 Drive Bays included in the case. The Front also includes an X-Dock which can be used to Plug-in a SSD Drive, The top design comes with a handle and the front connector panel which includes Power On/Off, LED On/Off, 2 x USB 2.0, 2 x USB 3.0, E-Sata, Audio Microphone Jacks and HDD/CPU Usage LED's. There are also 3 Holes at the back to allow for watercooling setups. A meshed side panel is included on the case which may allow room for 2 120mm fans but this is yet no known.
Cooler Master Storm TrooperModel (SGC-5000-KKN1)
Brand ................................................................. COOLER MASTER
Series ................................................................. CM Storm Series
Model .................................................................. Trooper
Specs
Type ......................................................... ATX Full Tower
Color ................................................................ Black ( Future Model may come in Red and White)
Case Material ....................................... Steel / Plastic Front Bezel Metal Mesh drive covers and plastic Rubber covered Top Cover
Power Supply ........................................ Standard ATX PS2/EPS (SOLD SEPERATLY )
Power Supply Mounted ....................................... Bottom
Motherboard Compatibility ........................................ Micro-ATX, ATX, XL-ATX
Side Panel Window ...................................................... Sold Separately ... Available April 2012
Expansion
External 5.25" Drive Bays ......................................... 6 But Expandable to 9
Internal 3.5" Drive Bays ......................................... 8 (converted from 5.25" bay by two 4-in 3 HDD modules)
Internal 2.5" Drive Bays ......................................... 13 (converted from 5.25" bay by two 4-in 3 HDD modules)
Expansion Slots ....................................................... 9+1
Front Ports
Front Ports ................................................................ USB 3.0 x 2 (internal),
.................................................................................................. USB 2.0 x 2,
.................................................................................................. e-SATA x 1,
.................................................................................................... Audio In and Out ( Supports HD audio)
Cooling System ............................................................. 120mm Fans
....................................................................................................... 2 x 120 mm LED Front Fan, 1200 RPM, 17 dBA
....................................................................................................... 2 x 120 mm Side Fan (optional)
....................................................................................................... 2 x 120 mm Bottom Fan (optional)
140mm Fans ...................................................................... 1 x 140 mm Rear Fan,
................................................................................................... 1200 RPM, 19 dBA (converted to 120 mm fan)
200mm Fan ........................................................................ 1 x 200 mm Top Fan,
............................................................................................................ 1000 RPM, 23 dBA
................................................................................. (convertible to 2 x 120 / 140 mm fan if desired. Holes already precut)
Physical Specifications
Dimensions ....................................................... 23.8" x 9.8" x 22.8"................60.45 cm x 24.89 cm x 57.91 cm.
Weight .............................................................................. 31.7 lbs ............................... 14.38 Kg.
Features
The first full tower chassis with two 90 degrees rotatable 4-in-3 HDD modules
The first with an easy-to-carry handle, and hidden tool box for storing private goods
Easily removable dust filters on intakes
A built in fan controller for cool or quiet operation
Supports up to 14 hard-drives for future upgrades
Convenient external 2.5" HDD/SSD X-dock
Supports high-end hardware, includes XL-ATX board, multiple GPUs in SLI or Crossfire
BenchmarkReviews Says.
The sturdy, rubber-padded handle dominates the top of the Storm Trooper. Behind the handle is a meshed area covering the top of the case and providing exhaust airflow for the included 200mm top fan. The fan can be removed and replaced with a 2x120mm radiator. The front and top of the case are covered in a soft-touch, rubber-like material.
Benchmark Reviews also reports.
A giant illuminated power button with the Storm logo dominates the I/O panel at the top front of the case; below it are buttons for the built-in fan controller, which can control the lights of three fans and the speed of four fans. By pressing the "-" and "+" buttons, you can choose between six different fan speeds, with LEDs above the switches visually indicating the chosen speed. There are also power and hard drive activity LEDs, microphone and headphone jacks, a reset button and ESATA port, and four widely-spaced USB ports. The wide spacing of the USB ports will minimize the chance of "fat" USB devices interfering with adjacent ports. There is no FireWire (IEEE 1394) port, but this is falling out of use anyway and most users won't miss it. The two SuperSpeed USB 3.0 ports are connected to a cable terminating in a USB 3.0 header, which is only useful if you have a recent motherboard that has one of these headers. Surprisingly, Cooler Master does not provide a USB 3.0->USB 2.0 adapter cable, so if your motherboard doesn't have a USB 3.0 header, you won't be able to use these ports.
One odd thing is that Cooler Master doesn't supply a power light header for your motherboard's front panel connector; instead, the power LED gets its electricity from the same 4 pin Molex connector the fan controller does. While this works, it means you don't get a blinking power light when you put your computer to sleep.
The Cooler Master Storm Trooper Club
is dedicated to the honorable.
Seal Team VI
RIP "08-06-2011"
This case was also introduced on the 20th Anniversary of Nevermind Album from Nirvana..
Kurt.. RIP.. We loved you and you didn't feel that you deserved it. But who does?
