I am not sure but doesn't the O11 D have hot swappable connections in the cages? If so that bracket will only populate one drive per slot. Since the cages only fit up to two 3.5 HDDs, that's two points of connection and you're talking about putting four drives into one cage. Doesn't seem like that will work unless the O11D doesn't have connections in the Cage. If not, it will work. :thinking:@Ceadderman
Thanks no I will get 2 of them which lets me populate 4 drives. One only has 2 SSD cages so I will get 2 of them and mount one to one drive sled and one to another.
I see that Lian Li drive cage sleds use bottom screws to mount the HDD and that Drive bracket has holes on the side and bottom to mount so I wanted to make sure I was fine
Edit... NOT Hot Swappable. I just looked it up, through Google Images and there is a guy who is attempting to mount his Sound Card into the back slot and has a HDD mounted in the front one. With no forward panel in the front it looks like you're good to go with 2 of those 2.5 SSD adapters.
~Ceadder :drink:
