How do I join?
It's pretty simple, just post a picture of the IFX-14, CoGage Arrow, Silver Arrow, Silver Arrow SB-E or Silver Arrow SB-E Extreme installed in your rig with the following information:
- Fan configuration details. Example: Push/Pull with x2 TY-140
- Case make and model. Example: Corsair Obsidian 650D
- Motherboard make and model. Example: GIGABYTE GA-890GPA-UD3H Rev 2.1
- RAM make, model and total number of DIMMs. Example: Corsair XMS3 x4
- Any other relevant information such as PCI slots covered, etc would be greatly appreciated!
Add the club to your sig!
::: Thermalright Silver Arrow / SB-E Club :::
[CENTER][B]::: [URL=http://www.overclock.net/t/990633/the-official-thermalright-silver-arrow-sb-e-club/0_20#post_13127965]Thermalright Silver Arrow / SB-E Club[/URL] :::[/B][/CENTER]
IFX-14 & Cogage Arrow
Silver Arrow
Special Features
OCN Member Contagion
SPCR
[H]ardOCP
Overclockers Club
Vortez
X-bit Labs
Motherboard Compatibility List (Click to view.)
Specifications
4 X 8mm large sintered heat-pipes efficiently remove excessive heat away from the CPU, allowing for great Overclocking potential .
Nickel Plated Base and Heatpipes, increase the longevity of the heatsink by slowing oxidation and deterioration rates… maintained performance over time.
Double fin stack design, provides each tower with an impressive 147 x 103mm of surface area for heat dissipation
Special Arrow fin design, which allows cool air to pass through while rapidly moving heat away and maintaining a quiet operating volume .
Soldered Copper Base, ensure the highest of Thermal conduction.
Support for Multiple-Platforms: Intel Socket 1366/1156/775 & AM2/AM3 .
Includes Two TY Series Ultra Low noise 160*140*25mm PWN controlled fan .
ReviewsHeatsink Dimensions: Length 147mm x Width 123mm x Height 166mm
Cooler weight: 825 g (excluding Retention Hardware and Fan) .
Heat-pipe: 8mm Sintered Heat-pipe x4 units
Cooler Base Material: C1100 Pure Copper with Nickel Plating
Fan Compatibly: 120x25mm / 140x25mm / 120x38mm
Fan dimensions: Length 160mm x Width 25mm x Height 140mm
Fan Speed: 500~1300RPM
Fan Air flow: 28~73.6CFM
Fan Noise Level: 17~21dBA
SPCR
[H]ardOCP
Overclockers Club
Vortez
X-bit Labs
Silver Arrow SB-E
More info coming soon...
ReviewsSpecial features:
8 X 6mm sintered heat-pipes effectively takes away excessive heat from the CPU when overclocked, Nickel Plated heat-pipes, slower Oxidation and deterioration of the heat-pipes, provides longer period of Thermal conductivity.
Double fin design , each side with 154mm*120mm heat dissipation area, can be used with 14 or 15 cm fan ( fan clips included).
Special Arrow fin design, which allows cool air to pass through and take heat away rapidly, effectively provide cooling for the cpu.
Support Multiple-Platforms. Can be used on Socket 2011/1366/1155/1156/775 Platform, and AM2/AM2+/AM3/AM3+/FM1 Sockets.
Including TY-150&TY-141 Ultra low noise PWM fans and PWM Y-Cable. With the compatibility of up to 3 fans maximum.
Technical Spec:
Cooler Dimension: Length 155mm x Width 105mm x Height 165mm (without fans) 170mm x Width 130mm x 170mm (with both TY-141 and TY-150 fan installed)
Cooler weight: 1124g (including two Fan, without mounting brackets)
Heat-pipe: 6mm Sintered Heat-pipe*8 units
Cooler Base Material: C1100 Pure Copper with Nickel Plating.
Fan Dimension:
TY-150 Length 170mm x Width 26.5mm x Height 150mm
TY-150 Fan Speed: 500~1100 RPM (PWM)
TY-150 noise level: 17~21dBA
Fan Airflow: 38~84CFM
TY-141 Length 170mm x Width 26.5mm x Height 150mm
TY-141 Fan Speed: 900~1300 RPM (PWM)
TY-141 Fan noise level: 21~25dBA
Fan Airflow: 28-74CFM
Members
Case, motherboard, fan config and other related information included if available.
Click on member name to view posted picture.
Segovax
kody7839
reisya
KhaoticKomputing
qussl3
Blueduck3285
tsuchiro
GeforceGTS
tw33k
nohcho
solsamurai --- SB-E - Push/Push - Corsair 650D - GIGABYTE GA-Z77X-UD4H Rev 1.0 - Corsair XMS3 x4
Murderouscore
faulkton
1nst1nct1ve
alpsie
Nightz2k
AWESOME_3_SOME
Cyph3r
fatalizer
Kasaris
compudaze
e1jefe
jza70
Neo_Morpheus
matty_AFC
Nexus6
capitaltpt
BradleyW
gsa700
Cosmic Collision
Cyph3r
HWI
justin8
Czarnodziej
nezzarix
Raunts
adzsask
X.rated
TheOctane
vivi2000
mearnshaw
bashywash
LukaTCE
WORLDs
SkyeHack
WetMacula
jhatfie
jizzin
Badness
onthemour
brumby05
sm00nie
tizm
bce22
XtremlyDementeD
IXcrispyXI
kscaveman
Helikaon
Altstadt
Bulldognutz
kevindd992002
Madmanden
inertia8
nekromantik
mastrflexx
Buzzin92
XtremeBawls
Red1776
matrix2000x2
inertia8
firestorm1
jacrabby
MercurySteam
Tom Thumb
Milamber
calvinbui
Bookhead
solaris304
cympaulife
guillaume07
Sean Webster
onoff
Emissary of Pain
importflip
mikupoiss
HappySlayerUK
Jcoffin1981
OnrA
KILLER_K
`Kyle
hemphill
ilikebeer
Yananaz
drBlahMan
Kuhsnjig --- SB-E - Push/Push - CM Centurion - ASRock M3A790GXH/128M
Bogga --- SB-E - Push/Push - Corsair 600T - Asus P8Z68-V Gen3
David J. --- SB-E - Push/Push - Corsair 300R
grinny --- SB-E - Push/Push - CM HAF X - Gigabyte GA-990FXA-UD3
phez --- SB-E - Push/Push - Silverstone TJ08-e - Asus Maximus V Gene
Velathawen --- Cogage Arrow - Lancool K62 - AsRock P67 Extreme 6 - Ripjaw X x2
Wakakuu --- SB-E - Pull/Pull - Corsair 600T
.Griff. --- Silver Arrow - Push/Push - Corsair 600T - MSI P55-GD80 - Geil Ultra Series
Matt-Matt --- SB-E - Push/Push - HAF 932 - Gigabyte Z77x-D3H - Samsung Eco
wermad --- Silver Arrow - x3 TY-140 Push/Push/Pull - Xigmatek Elysium - Asus P8P67 WS Revolution - Samsung MV-3V4G3D/US 8GB (2x4GB)
icekreme1002 --- SB-E - TY-150 - Fractal Design R3 - GA-890FXA-UD5 rev 2.1 - G.SKILL Ripjaws X
Xaifodin --- SB-E - TY-150
marsey99 -- IFX-14!
madcow007 --- SB-E - Push/Push - Antec Solo 2 - Gigabyte GA-970A-UD3 - G.SKILL Ares x4
motherpuncher --- SB-E - Push/Push
homestyle --- SB-E - TY-150 - Fractal Design Define R4 - Gigabyte Z77X-UD3H - 8GB Samsung
SteddyLie --- SB-E - Pull/Pull - Lancool First Knight PC-K63 - MSI A75MA-G55 - Patriot Viper Extreme 8GB
jovanni --- SB-E - TY-140 x3
worms14 --- SB-E (Black & White Edition) - Push/Pull - Fractal Design Arc Midi - ASRock P67 PRO3 - Geil Laggera
Wyllliam --- SB-E - Pull/Pull - Aerocool Xpredator X3 - Asus P8Z77-V - Corsair 1600 x2
neoroy --- SB-E Extreme - Push/Pull - test bench - MSI Z77A-GD80 - Corsair Vengeance
micfild --- SB-E Extreme - Push/Pull - CM 690 II - Asus P8Z77-V Deluxe - Crucial Ballistix Tactical
splinterize --- Silver Arrow - Pull/Pull - Bitfenix Prodigy - Asus P8Z77-i Deluxe - Kingston HyperX
amd-pcmarlow --- SB-E Extreme - Pull/Pull - M5A99X EVO R2.0
ivanlabrie --- Silver Arrow - Push/Push - CM 690 II - Asus Maximus V Gene - G.Skill Ripjaws X x4
xvince1 --- Cogage Arrow - Push/Push (Silverstone FHP141 x2) - Corsair 650D - Gigabyte X58A-OC
DeadSkull --- SB-E - Push/Push Vertical Orientation - CM HAF 932 - Gigabyte EP45-UD3P rev 1.0 - G.Skill Pi 9600 8GB
Konkistadori --- SB-E - Push/Push - Asus P6T DLX V2 - Corsair XMS3 3x 2GB
Anusha --- SB-E Extreme - Pull/Pull - Silverstone Raven RV03 - ASRock Z68 Extreme4 - Corsair Vengeance x4
FragZero --- SB-E Extreme - TY-143 x3 - Fractal Design Arc Midi R2 - Asus P8Z68 Deluxe - Ballistix Tactical Low Profile
misterck --- SB-E - Push/Push - NZXT Phantom 410 - MSI Z87-G45 - 2x 4Gb Corsair Vengance Low Profile
Karlz3r --- Silver Arrow - Pull/Pull - Enermax iVektor - ASUS P8Z68-V/GEN3 - G.Skill Sniper x2
kody7839
reisya
KhaoticKomputing
qussl3
Blueduck3285
tsuchiro
GeforceGTS
tw33k
nohcho
Murderouscore
faulkton
1nst1nct1ve
alpsie
Nightz2k
AWESOME_3_SOME
Cyph3r
fatalizer
Kasaris
compudaze
e1jefe
jza70
Neo_Morpheus
matty_AFC
Nexus6
capitaltpt
BradleyW
gsa700
Cosmic Collision
Cyph3r
HWI
justin8
Czarnodziej
nezzarix
Raunts
adzsask
X.rated
TheOctane
vivi2000
mearnshaw
bashywash
LukaTCE
WORLDs
SkyeHack
WetMacula
jhatfie
jizzin
Badness
onthemour
brumby05
sm00nie
tizm
bce22
XtremlyDementeD
IXcrispyXI
kscaveman
Helikaon
Altstadt
Bulldognutz
kevindd992002
Madmanden
inertia8
nekromantik
mastrflexx
Buzzin92
XtremeBawls
Red1776
matrix2000x2
inertia8
firestorm1
jacrabby
MercurySteam
Tom Thumb
Milamber
calvinbui
Bookhead
solaris304
cympaulife
guillaume07
Sean Webster
onoff
Emissary of Pain
importflip
mikupoiss
HappySlayerUK
Jcoffin1981
OnrA
KILLER_K
`Kyle
hemphill
ilikebeer
Yananaz
drBlahMan
marsey99 -- IFX-14!
Many thanks to Ikthus for originally starting this club.
