BSOD codes for overclocking
BSOD Codes for i7 x58 chipset
0x101 = increase vcore
0x124 = increase/decrease QPI/VTT first, if not increase/decrease vcore...have to test to see which one it is
0x0A = unstable RAM/IMC, increase QPI first, if that doesn't work increase vcore
0x1A = Memory management error. It usually means a bad stick of Ram. Test with Memtest or whatever you prefer. Try raising your Ram voltage
0x1E = increase vcore
0x3B = increase vcore
0x3D = increase vcore
0xD1 = QPI/VTT, increase/decrease as necessary, can also be unstable Ram, raise Ram voltage
0x9C = QPI/VTT most likely, but increasing vcore has helped in some instances
0x50 = RAM timings/Frequency or uncore multi unstable, increase RAM voltage or adjust QPI/VTT, or lower uncore if you're higher than 2x
0x109 = Not enough or too Much memory voltage
0x116 = Low IOH (NB) voltage, GPU issue (most common when running multi-GPU/overclocking GPU)
0x7E = Corrupted OS file, possibly from overclocking. Run sfc /scannow and chkdsk /r
BSOD Codes for SandyBridge
0x124 = add/remove vcore or QPI/VTT voltage (usually Vcore, once it was QPI/VTT)
0x101 = add more vcore
0x50 = RAM timings/Frequency add DDR3 voltage or add QPI/VTT
0x1E = add more vcore
0x3B = add more vcore
0xD1 = add QPI/VTT voltage
"0x9C = QPI/VTT most likely, but increasing vcore has helped in some instances"
0X109 = add DDR3 voltage
0x0A = add QPI/VTT voltage
Please feel free to comment, advise, correct, and add to this list. I am not the original author and will not take credit for it. I simply thought that it should be posted by itself. I am only repeating the info that I got here at OCN. This is currently for Intel i7 systems, but I would like for everyone to help me set it up for other systems as well.
Thanks, just giving back,
/eVo/HaMMeR=GoM=
/eVo/HaMMeR=GoM=
