1 - 20 of 263 Posts
Hello guys!
The old "Programming Challenge" thread is quite outdated and desperately needs to be updated for this decade!
I, therefore, have created a new thread.
We have some programmers on this site and it would be good to kick off these programming challenges again.
Note about challenge : This is geared toward beginner or intermediate programmers. The challenges will be easy, yet hard enough to be challenging for beginners. There will be no restriction to which languages you can use. You can use an online compiler to show that it executes and you can post your code here.
Each challenge will have a time duration of about a week so be sure to submit your entry within that time.
Thank you.
LATEST PROGRAMMING CHALLENGE: Challenge # 7 posted!
If you are participating, add in your name HERE
https://docs.google.com/spreadsheet/pub?hl=en_US&hl=en_US&key=0Am3S8fDXvrogdE01TlNReU5fTFBQU2ZueWw4ZFI2ZWc&single=true&gid=0&output=html&widget=true
~ {Unregistered}
Discussion Starter · #2 ·
Okay, so honestly the poll turn out is better than I expected.
I'll try to issue the first programming challenge by today or tomorrow but I'd like to tell you guys that I'm a little busy during this week and can only guarantee that I'll issue the challenge by the end of this week.
If any of you guys want to volunteer and post the challenge or would like to contribute in any way, then do post here.
By the way, this is also an extra bump to make sure more people see this.
Hopefully, this will be up and running by today!
Originally Posted by Kyleinator View Post
How advanced will the challenges be? I have taken intro to C++, c, and Java. Will that be enough or is this aimed towards advanced programmers?
No, this is geared toward beginner or intermediate programmers. The challenges will be easy, yet hard enough to be challenging for beginners. There will be no restriction to which languages you can use. You can use an online compiler to show that it executes and you can post your code here.
Glad you asked; I think I should add this to the OP.
Okay so guys, here is the very first programming challenge of this thread. Remember that there is no restriction as to which language you have to use (even though I do expect that most of you will be using C++, Java or Python).
I'm going to start of with something really simple (depending on your programming skill of course), since I'm not really sure how well you're going to perform. The difficulty levels of future challenges will be based on your response in this challenge.
Here's what you have to do:
Write code which just displays a pattern similar to the one below:
You'll have to make it customisable so that it is possible to change the number of maximum *'s that appear. For example, in the pattern shown above, the maximum number of *'s is 5. The pattern increases the number of stars in every row until it reaches the maximum number and then decreases the number of stars (asterisks). You can either allow it to add input from the user, or you can add input from an object. The only requirement is that you must be able to change the size of the pattern (number of *'s) without re-doing or adding anything significant to the code.
Hoping that at least the 16 people who voted actually make an effort to work on this.
~{Unregistered}
You should post the challenge in a spoiler box in the first post, so we can easily go back to see it without going to far in the topic.
How do we submit the code?
I did a little something with c++ on codepad.org.
I'm at school and I don't have access to anything better (but still, console c++ is quite basic).
I also can't put a user input because it doesn't support it.
Moderator
FreeBASIC?
Will do.
As for the code, codepad.org is fine. Instead of adding user input, you can just make it so that changing the value of a particular variable can allow you to change the number of stars printed. Input is the easy part; the actual important part of the program is that which actually executes your planned algorithm. If you can do that, then it's absolutely fine.
Moderator
FreeBASIC
stars.bas
dim as integer i, j, c, quit
dim as string s
s = command(1)
if val(s) > 0 then
    c = val(s)
else
    while quit = 0
        input "Enter a number:",s
            if val(s) > 0 then
                c = val(s)
                quit = 1
            end if
        sleep 1
    wend
end if
? "Value chosen was: " & c
for i = 1 to c
    for j = 1 to i
    next
next
for i = (c - 1) to 1 step -1
    for j = 1 to i
    next
next
Usage:
stars.exe 5
Would output:
Or you could just run it straight and it prompts you for a number
Codepad isn't working for me. Can I just submit my code? If so, here it is. It's in c++ and takes the number of asterisks you want in the largest/center line as a command line argument. Usage is: asterisks number_of_asterisks
#include<iostream>
#include<cstdlib>
using namespace std;
class A{
    public:
        void print();
        int n;
        int start;
void A::print(){
    int i, s;
    s = start;
    if(start == n){
        for(i = 0; i < n; i++){ cout << "*"; }
        cout << endl;
        return;
    for(i = 0; i < s; i++){ cout << "*"; }
    cout << endl;
    start++;
    print();
    cout << endl;
    return;
int main(int argc, char **argv){
    int n, i, j;
    A *a;
    if(argc != 2){
        cout << "Usage: asterisks number-of-asterisks" << endl;
        exit(1);
    n = atoi(argv[1]);
    a = new A;
    a->n = n;
    a->start = 1;
    a->print();
    return 0;
http://ideone.com/xXb2o
public class Main {
    public static void main(String[] args) {
        int count=5;
        for (int i=1;i<=count*2;i++) {
            if (i == count) {
            for (int j=0;j<count;j++)
                System.out.print("*");
            } else {
                for (int j=0;j<(count-Math.max(count-i, i-count))%count;j++)
            System.out.println();
Output:
http://codepad.org/y1mcS8Sf
#include <iostream>
int main()
        int numberOfCarac = 5;
        int i, h;
        for(i = 0; i < numberOfCarac; i++)
                for (h = 0; h < i; h++)
                        cout << "*";
                cout << endl;
        for(i = numberOfCarac; i > 0; i--)
                for (h = i; h > 0; h--)
                        cout << "*";
                cout << endl;
        return 0;
Here mine, codepad was not working and so I could not test it.
Interesting to see the different ways people tackle the challenge
http://www.ideone.com/BKjk4
#include <iostream>
int main() {
        int num, i, k;
        cin >> num;
        if (num < 1){
                cout << "Number entered must be above 0";
                return 0;
        for (i = 0; i <= 2*(num)-1; i++){
                for (k = (i<num) ? (2*(num-i)) : 0; k <= 2*(num)-i-1; k++) cout << "*";
                cout << "\n";
        return 0;
*THIS SPACE FOR RENT*
Here's what I came up with using C#:
static void Challenge1()
    Console.WriteLine("Enter Number");
    Int32 numOfAsterisks = Int32.Parse(Console.ReadLine());
    Console.WriteLine();
    for (Int32 i = 1; i <= numOfAsterisks; i++)
        for (Int32 t = 0; t < i; t++)
            Console.WriteLine("*");
    for (Int32 i = (numOfAsterisks - 1); i >= 1; i++)
        for (Int32 t = i; t > 0; t--)
Coded it on my work comp and then typed up on my laptop separately, but it should be correct.
#include <stdio.h>
#include <stdlib.h>
    int i,j; int step = 1; int star = 1;
    int count = 2*atoi(argv[1])-2;
    if(argc == 2){
        for(i = 0; i <= count; i++){
            for(j = 0; j < star; j++) printf("*");
            printf("\n");
            if(i == count/2) step = -step;
            star += step;
in C, takes a command line argument for the number of stars, so stars 5 would output
import java.io.*;
import java.util.*;
public class OCNChallenge
  public static void main(String args[])
    Scanner kbReader = new Scanner(System.in);
    System.out.print("Please enter the maximum amount of stars: ");
    int num = kbReader.nextInt();
    DrawStars draw = new DrawStars(num);
    draw.Draw();
public class DrawStars
  public DrawStars(int a)
    numstars=a;
  public void Draw()
    String s = "*";
    for(int i=0;i<numstars;i++)
      for(int j=0;j<=i;j++)
        System.out.print(s);
      System.out.print("\n");
    for(int k=0;k<numstars;k++)
      for(int l=(numstars-1);l>k;l--)
  private int numstars;
j
usage:
javac OCNChallenge.java
java OCNChallenge
Takes user input for number of * to draw. * could also be replaced with any other symbol.
Nice website, I think I will try it.
It's cool to look at how people do it, and what language they use.
I love to use on-site compiler so that I can program on any computer (even my tablet) without any problem.
For some other challenge, you could ask to make some form with *.
I remember doing it 2 years ago when I first start my computer technology course at school. Doing a square, a triangle, a diamond. Full or empty. And even some more complex form like a circle... didn't manage to do this one...
Python here, went for simple to understand rather than fancy code, but it gets the job done.
NUMBER_OF_STARS = 5
i = 1
while i <= NUMBER_OF_STARS:
    print ('*' * i)
    i = i + 1
while i > 0:
    print ('*' * i)
    i = i - 1
1 - 20 of 263 Posts
