This is what happened. you should be able to tell from just the title.
http://www.overclock.net/laptops-not...r-netbook.html
and replaced my hard drive and now i got a new problem. my computer randomly shuts down and in the event viewer, i get this "The system was shut down due to a critical thermal event."
it seems like the my computer does shut down when my computer's doing a lot of processing but the bottom side of my laptop doesnt seem that hot (barely warm) at all.
Shutdown Time = 2010-03-08T17:37:08.620838900Z
ACPI Thermal Zone = ACPI\\ThermalZone\\TZ00 "
it usually does this more often when im using just battery, and it seems to get a little better when i take out the battery and just use the ac power.
ive tried reinstalling the ACPI drivers but that did not help. i doubt that this really is a heat problem... but im not completely sure. anyone here knows whats going on? the fans running all the time btw.
