1 - 6 of 6 Posts
It'll work, it's pretty much universal (don't think am2 works)<img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
Looking at your system specs it looks like it'll work with your case, but i want to be sure. What are the dimensions of your case?
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16811129158" target="_blank">http://www.newegg.com/Product/Produc...82E16811129158</a> .....this is the exact deminsions.....Brand Antec <br />
Series PERFORMANCE TX <br />
Model TX1050B <br />
Spec <br />
Type ATX Mid Tower <br />
Color Black <br />
Case Material Steel <br />
With Power Supply Yes <br />
Power Supply 500W ATX12V v2.0 <br />
Motherboard Compatibility 12" x 9.6" ATX <br />
With Side Panel Window No <br />
Expansion <br />
External 5.25" Drive Bays 4 <br />
External 3.5" Drive Bays 2 <br />
Internal 3.5" Drive Bays 4 <br />
Expansion Slots 7 <br />
Front Ports <br />
Front Ports 2 x USB, 2 x Audio, 1 x IEEE1394 <br />
Cooling System <br />
80mm Fans No <br />
120mm Fans 1 x 120mm Tricool rear fan with 3-speed switch <br />
Side Air duct Yes <br />
Physical Spec <br />
Dimensions 20.6" x 8.1" x 18.6" <br />
Features <br />
Features TAC Compliant <br />
Meet Intel's Thermally Advanced Chassis (TAC) design guide<br />
Built-in washable air filter <br />
<br />
PSU Main connector : 20+4-pin<br />
SP-500 PSU includes Advanced Cable Management, use only the cables you need
The BT works with all skt939 boards. It really comes down to your PC case (is it big anough because the BT is BIG). <br />
Personally I would recommend another cooler, probably a Scythe one. The BT is excellent for single core but lags behind when it comes to dual core. Still an excellent cooler, but others may be a better buy. Just saying.<br />
<br />
Edit: The BT should fit inside that case.
<tr>
<div>
Originally Posted by <strong>Melcar</strong>
<a href="showthread.php?s=fb118d83aa0ea05832d812d721028acf&p=1382632#post1382632" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Edit: The BT should fit inside that case.</div>
</td>
</tr>
</table>
</div>Yes i was about to say....
<tr>
<div>
Originally Posted by <strong>droby1987</strong>
<a href="showthread.php?s=7cbacc57dd35bcffd2623e1b5502316d&p=1381911#post1381911" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Is the TT BT a 939 socket cpu cooler that will fit an Athlon Dual Core 4200 processor?</div>
</td>
</tr>
</table>
</div><a href="http://www.thermaltakeusa.com/product/Cooler/Retail/cl-p0310/cl-p0310.asp" target="_blank">http://www.thermaltakeusa.com/produc...0/cl-p0310.asp</a><br />
work on all new MOBOs. mayb even AM3 lol
1 - 6 of 6 Posts
