The Goals of this Testing Process:
What I am studying here is the following three scenarios, using Crysis:Warhead as my benching application:
1) The effect of upgrading from a P35 with a core2duo, to an x58 with an i7, when using a BFG GTX295, using a common, easily attained overclock on each processor, and
2) The effect of upgrading from a 750 SLI with a core2duo, to an x58 with an i7, when using a SLI GTX280, again using a common, easily attained overclock on each processor, and
3) The effect of upgrading from a GTX295 to an SLI GTX280 setup, on an x58 board with an i7 processor, again using a common, easily attained overclock on the processor. Note that I was primarily interested in the difference between these two GPU setups when using EQUAL GPU (and CPU, equal everything, basically) clocks, so my analysis is done on that scenario.
GPU's Tested (More like a Legend for Tests Below):
GTX 295n (p35, [email protected] 4.0GHz, PCI-Ex 1.1 1x16X, STOCK SPEED)
GTX 295i (x58, [email protected]+turbo=3.466GHz, PCI-Ex 2.0 2x16X STOCK SPEED)
GTX 295ix (x58, [email protected]+turbo=3.466GHz, PCI-Ex 2.0 2x16X, OVERCLOCKED TO GTX280 SPEED)
2xGTX280n (750 SLI, [email protected] 4.0GHz, PCI-Ex 2.0 2x16X STOCK SPEED)
2xGTX280i (x58, [email protected]+turbo=3.466GHz, PCI-Ex 2.0 2x16X STOCK SPEED)
Boards Used:
P35 = Asus p5k-e wifi (GTX295)
750 = Evga 750 SLI FTW (SLI GTX280)
x58 = Gigabyte ex58-ud4p (GTX295, SLI GTX280)
Other Details:
All are DX9 Tests, using Microsoft Windows XP Professional Service Pack 2, using Crysis Warhead (unpatched), and the FBWH Benchmarking Tool. All tests EXCEPT the p35 tests were run using the latest (182.08 WHQL) drivers.
Brief Summary of Results
(in case you lack the stomach for sorting out my results below):
For the GTX295, the move FROM the PCI Express 1.1 P35 board with an e8400 processor at 4.0GHz TO the PCI Express 2.0 X58 board with the i920 processor at 3.466 yielded nearly universally POSITIVE results, showing GAINS in 11 of 15 of the tests. The overall range of gain was between -2.6% and +5.4%, with the preponderance of data showing a delta of somewhere around +4% for this (roughly 700 dollar) platform change.
For the SLI GTX280 setup, the move FROM the PCI Express 2.0 750 nforce-SLI board (2x16 lanes) with the e8400 processor at 4.0GHz TO the PCI Express 2.0 (2x16 lanes) X58 board with the i920 processor at 3.466 yielded nearly universally NEGATIVE results, showing LOSSES in 9 of the 12 of the tests, and improvements in only one of 1 the 12. The overall range of gain was between -2.9% and +9.0%, with the preponderance of data showing a delta of somewhere around -1.5% for this (roughly 700 dollar) platform change.
Once I have installed a better cooler on my system, I will happily investigate whether or not raising the clocks of the i7 will yield further positive results, but based on my fairly extensive benchmark observations over the course of my lifetime, I strongly suspect that improvements due to further overclocking will be minimal, as these are (purposefully) largely GPU-BOUND tests, intended to reflect the kind of gaming settings that those of us who buy $500 graphics solutions are looking to be playing at.
In comparing the performance of the GTX295 and the SLI GTX280 (both at equal clocks, that of the BFG GTX280 OC) on the Core i7 setup, we see a clean-sweep. The SLI setup defeats the dual-card solution in every test. The range of improvement seen by stepping up from the GTX295 to the SLI setup (at equal clocks) was between +6.1% and +13.3%, with the average perf gain for SLI coming in at around +8.5% improvement. As one might expect, given that the primary benefit of the 2x280GTX setup would be it's 15% memory bandwidth advantage, the gains of the SLI setup were more pronounced in the two sets of tests where AA was ON. The ability of the GTX280 SLI setup to overclock slightly higher also produces a slight improvement in it's margin of victory in the 'max overclocked' tests.
I should also add that there is a fairly consistent trend that shows using an i7 processor DOES raise minimum frame rates, and although it's not universal, I think overall its a phenomenon worthy of some study and consideration.
DETAILED RESULTS:
************ GAMER, 1680x1050, 0xAA TESTS ***************
GAMER 2X @ Map: ambush @ 0 1680 x 1050 AA 0xx
GTX 295n Framerate [ Min: 25.70 Max: 88.25 Avg: 66.41 ]
GTX 295i Framerate [ Min: 37.58 Max: 92.13 Avg: 68.31 ]
% CHANGE P35 ([email protected]) TO X58 ([email protected]) For GTX295 on Stock Clocks = +2.9%
2xGTX280n Framerate [ Min: 26.60 Max: 97.21 Avg: 70.58 ]
2xGTX280i Framerate [ Min: 37.07 Max: 102.84 Avg: 76.95 ]
GTX 295ix Framerate [ Min: 35.68 Max: 96.11 Avg: 72.49 ]
% CHANGE 750SLI ([email protected]) TO X58 ([email protected]) For SLI GTX280 on Stock Clocks =+9.0%
% CHANGE GTX295 TO SLI GTX280 on i7 on Equal Clocks= +6.1%
GAMER 2X @ Map: frost @ 0 1680 x 1050 AA 0xx
GTX 295n Framerate [ Min: 42.66 Max: 75.17 Avg: 59.15 ]
GTX 295i Framerate [ Min: 44.63 Max: 78.79 Avg: 61.53 ]
% CHANGE P35 ([email protected]) TO X58 ([email protected]) For GTX295 on Stock Clocks = +4.0%
2xGTX280n Framerate [ Min: 51.58 Max: 88.94 Avg: 70.30 ]
2xGTX280i Framerate [ Min: 50.60 Max: 88.56 Avg: 69.74 ]
GTX 295ix Framerate [ Min: 41.99 Max: 82.99 Avg: 65.05 ]
% CHANGE 750SLI ([email protected]) TO X58 ([email protected]) For SLI GTX280 on Stock Clocks = -0.8%
% CHANGE GTX295 TO SLI GTX280 on i7 on Equal Clocks= +7.2%
GAMER 2X @ Map: avalanche flythrough @ 8 1680 x 1050 AA 0xx
GTX 295n Framerate [ Min: 36.91 Max: 72.85 Avg: 55.94 ]
GTX 295i Framerate [ Min: 42.73 Max: 76.65 Avg: 58.98 ]
% CHANGE P35 ([email protected]) TO X58 ([email protected]) For GTX295 on Stock Clocks = +5.4%
2xGTX280n Framerate [ Min: 30.47 Max: 89.09 Avg: 70.35 ]
2xGTX280i Framerate [ Min: 45.98 Max: 87.96 Avg: 69.10 ]
GTX 295ix Framerate [ Min: 39.69 Max: 82.88 Avg: 62.96 ]
% CHANGE 750SLI ([email protected]) TO X58 ([email protected]) For SLI GTX280 on Stock Clocks = -1.7%
% CHANGE GTX295 TO SLI GTX280 on i7 on Equal Clocks= +9.7%
************ GAMER, 1680x1050, 4xAA TESTS ***************
GAMER 2X @ Map: ambush @ 0 1680 x 1050 AA 4xx
GTX 295n Framerate [ Min: 25.42 Max: 66.82 Avg: 47.05 ]
GTX 295i Framerate [ Min: 32.85 Max: 70.95 Avg: 45.82 ]
% CHANGE P35 ([email protected]) TO X58 ([email protected]) For GTX295 on Stock Clocks = -2.6%
2xGTX280n Framerate [ Min: 24.50 Max: 75.90 Avg: 55.84 ]
2xGTX280i Framerate [ Min: 35.39 Max: 81.85 Avg: 55.84 ]
GTX 295ix Framerate [ Min: 35.18 Max: 69.58 Avg: 49.27 ]
% CHANGE 750SLI ([email protected]) TO X58 ([email protected]) For SLI GTX280 on Stock Clocks = 0%
% CHANGE GTX295 TO SLI GTX280 on i7 on Equal Clocks= +13.3%
GAMER 2X @ Map: frost @ 0 1680 x 1050 AA 4xx
GTX 295n Framerate [ Min: 31.54 Max: 55.58 Avg: 44.85 ]
GTX 295i Framerate [ Min: 30.47 Max: 57.67 Avg: 45.69 ]
% CHANGE P35 ([email protected]) TO X58 ([email protected]) For GTX295 on Stock Clocks = +1.9%
2xGTX280n Framerate [ Min: 35.60 Max: 69.85 Avg: 54.38 ]
2xGTX280i Framerate [ Min: 38.96 Max: 70.68 Avg: 54.35 ]
GTX 295ix Framerate [ Min: 34.71 Max: 62.52 Avg: 49.40 ]
% CHANGE GTX295 TO SLI GTX280 on i7 on Equal Clocks= +10%
GAMER 2X @ Map: avalanche flythrough @ 8 1680 x 1050 AA 4xx
GTX 295n Framerate [ Min: 26.80 Max: 56.97 Avg: 42.70 ]
GTX 295i Framerate [ Min: 34.97 Max: 58.77 Avg: 45.53 ]
% CHANGE P35 ([email protected]) TO X58 ([email protected]) For GTX295 on Stock Clocks = +6.6%
2xGTX280n Framerate [ Min: 34.62 Max: 69.54 Avg: 55.38 ]
2xGTX280i Framerate [ Min: 41.89 Max: 69.83 Avg: 54.70 ]
GTX 295ix Framerate [ Min: 37.03 Max: 64.03 Avg: 49.46 ]
% CHANGE 750SLI ([email protected]) TO X58 ([email protected]) For SLI GTX280 on Stock Clocks = -1.2%
% CHANGE GTX295 TO SLI GTX280 on i7 on Equal Clocks= +11%
************ ENTHUSIAST, 1680x1050, 0xAA TESTS ***************
ENTHUSIAST 2X @ Map: ambush @ 0 1680 x 1050 AA 0xx
GTX 295n Framerate [ Min: 13.40 Max: 60.92 Avg: 47.98 ]
GTX 295i Framerate [ Min: 31.51 Max: 63.57 Avg: 48.85 ]
% CHANGE P35 ([email protected]) TO X58 ([email protected]) For GTX295 on Stock Clocks = +1.8%
2xGTX280n Framerate [ Min: 23.41 Max: 71.92 Avg: 55.80 ]
2xGTX280i Framerate [ Min: 18.53 Max: 71.55 Avg: 54.96 ]
GTX 295ix Framerate [ Min: 34.21 Max: 68.10 Avg: 51.71 ]
% CHANGE 750SLI ([email protected]) TO X58 ([email protected]) For SLI GTX280 on Stock Clocks = -1.5%
% CHANGE GTX295 TO SLI GTX280 on i7 on Equal Clocks= +6.3%
ENTHUSIAST 2X @ Map: frost @ 0 1680 x 1050 AA 0xx
GTX 295n Framerate [ Min: 35.25 Max: 56.76 Avg: 46.27 ]
GTX 295i Framerate [ Min: 35.88 Max: 59.99 Avg: 47.94 ]
% CHANGE P35 ([email protected]) TO X58 ([email protected]) For GTX295 on Stock Clocks = +3.6%
2xGTX280n Framerate [ Min: 41.86 Max: 68.68 Avg: 55.46 ]
2xGTX280i Framerate [ Min: 39.72 Max: 68.38 Avg: 54.77 ]
GTX 295ix Framerate [ Min: 39.04 Max: 65.70 Avg: 51.20 ]
% CHANGE GTX295 TO SLI GTX280 on i7 on Equal Clocks= +6.9%
ENTHUSIAST 2X @ Map: avalanche flythrough @ 8 1680 x 1050 AA 0xx
GTX 295n Framerate [ Min: 29.53 Max: 56.18 Avg: 42.34 ]
GTX 295i Framerate [ Min: 32.84 Max: 57.93 Avg: 44.38 ]
% CHANGE P35 ([email protected]) TO X58 ([email protected]) For GTX295 on Stock Clocks = +4.8%
2xGTX280n Framerate [ Min: 36.29 Max: 66.68 Avg: 53.03 ]
2xGTX280i Framerate [ Min: 35.83 Max: 65.52 Avg: 51.53 ]
GTX 295ix Framerate [ Min: 36.90 Max: 62.21 Avg: 47.96 ]
% CHANGE 750SLI ([email protected]) TO X58 ([email protected]) For SLI GTX280 on Stock Clocks = -2.8%
% CHANGE GTX295 TO SLI GTX280 on i7 on Equal Clocks= +7.4%
************ ENTHUSIAST, 1680x1050, 4xAA TESTS ***************
(includes max overclocking tests for GTX295 & GTX280 SLI on i7)
ENTHUSIAST 2X @ Map: ambush @ 0 1680 x 1050 AA 4xx
GTX 295n (576/1242/1998) Framerate [ Min: 3.86 Max: 49.85 Avg: 36.75 ]
GTX 295i (576/1242/1998) Framerate [ Min: 24.76 Max: 50.50 Avg: 36.75 ]
% CHANGE P35 ([email protected]) TO X58 ([email protected]) For GTX295 on Stock Clocks = 0%
2xGTX280n (615/1350/2214) Framerate [ Min: 22.65 Max: 57.30 Avg: 43.15 ]
2xGTX280i (615/1350/2214) Framerate [ Min: 29.84 Max: 57.44 Avg: 42.78 ]
GTX 295ix (615/1350/2214) Framerate [ Min: 25.50 Max: 52.84 Avg: 39.06 ]
% CHANGE 750SLI ([email protected]) TO X58 ([email protected]) For SLI GTX280 on Stock Clocks = -1%
% CHANGE GTX295 TO SLI GTX280 on i7 on Equal Clocks= +9.5%
GTX 295n (666/1458/2376) Framerate [ Min: 5.90 Max: 57.95 Avg: 42.03 ]
GTX 295i (666/1458/2376) Framerate [ Min: 29.23 Max: 59.00 Avg: 42.03 ]
2xGTX280i (684/1458/2376) Framerate [ Min: 30.58 Max: 63.19 Avg: 46.45 ]
% CHANGE P35 ([email protected]) TO X58 ([email protected]) For GTX295 at Max Overclock = 0%
% CHANGE GTX295 TO SLI GTX280 at Max Overclock = +10.5%
ENTHUSIAST 2X @ Map: frost @ 0 1680 x 1050 AA 4xx
GTX 295n (576/1242/1998) Framerate [ Min: 26.49 Max: 43.31 Avg: 35.28 ]
GTX 295i (576/1242/1998) Framerate [ Min: 26.12 Max: 47.92 Avg: 36.66 ]
% CHANGE P35 ([email protected]) TO X58 ([email protected]) For GTX295 on Stock Clocks = +3.9%
2xGTX280n (615/1350/2214) Framerate [ Min: 33.27 Max: 55.89 Avg: 44.12 ]
2xGTX280i (615/1350/2214) Framerate [ Min: 30.43 Max: 55.32 Avg: 43.25 ]
GTX 295ix (615/1350/2214) Framerate [ Min: 27.52 Max: 50.30 Avg: 39.61 ]
% CHANGE 750SLI ([email protected]) TO X58 ([email protected]) For SLI GTX280 on Stock Clocks = -1.9%
% CHANGE GTX295 TO SLI GTX280 on i7 on Equal Clocks= +9.2%
GTX 295n (666/1458/2376) Framerate [ Min: 31.48 Max: 53.19 Avg: 43.52 ]
GTX 295i (666/1458/2376) Framerate [ Min: 31.36 Max: 54.99 Avg: 42.67 ]
2xGTX280i (684/1458/2376) Framerate [ Min: 31.06 Max: 60.91 Avg: 47.51 ]
% CHANGE P35 ([email protected]) TO X58 ([email protected]) For GTX295 at Max Overclock = -1.9%
% CHANGE GTX295 TO SLI GTX280 at Max Overclock = +11.3%
DirectX 9.0c ENTHUSIAST 2X @ Map: avalanche flythrough @ 8 1680 x 1050 AA 4xx
GTX 295n (576/1242/1998) Framerate [ Min: 22.65 Max: 43.22 Avg: 32.87 ]
GTX 295i (576/1242/1998) Framerate [ Min: 26.99 Max: 44.01 Avg: 34.08 ]
% CHANGE P35 ([email protected]) TO X58 ([email protected]) For GTX295 on Stock Clocks = +3.8%
2xGTX280n (615/1350/2214) Framerate [ Min: 31.70 Max: 52.26 Avg: 41.76 ]
2xGTX280i (615/1350/2214) Framerate [ Min: 32.70 Max: 51.34 Avg: 40.52 ]
GTX 295ix (615/1350/2214) Framerate [ Min: 28.87 Max: 47.97 Avg: 37.12 ]
% CHANGE 750SLI ([email protected]) TO X58 ([email protected]) For SLI GTX280 on Stock Clocks = -2.9%
GTX 295n (666/1458/2376) Framerate [ Min: 22.25 Max: 50.74 Avg: 37.69 ]
GTX 295i (666/1458/2376) Framerate [ Min: 31.15 Max: 51.67 Avg: 39.41 ]
2xGTX280i (684/1458/2376) Framerate [ Min: 29.21 Max: 56.75 Avg: 43.50 ]
% CHANGE P35 ([email protected]) TO X58 ([email protected]) For GTX295 at Max Overclock = +4.6%
% CHANGE GTX295 TO SLI GTX280 at Max Overclock = +10%
Boards Used:
Other Details:
DETAILED RESULTS:
