1 - 15 of 15 Posts
I use cotton on IHSless CPU's. But coffee filters work good on processors with IHSes. I use rubbing alcohol (I think it's 80%, but I'm not sure), NEVER use fingernail polish remover, because it is an acetone.
A lot of fingernail polish also has minerals in it to strengthen nails, good for nails, bad for processors. Like it was said above, try and get above 95%. Its hard because a lot of places only carry 70'ish% but if you try a lot of drug stores, your sure to find one. Make sure you really wipe the CPU off though because any lint or whatnot can spell trouble for your processor. I always use cotton swabs. Good luck!
I use my wifes nail polish remover pads(cotton rounds), they are lint free. Don't cost much , and you can get them at any drug store.
Uh oh.... Lol i read on arctic silver website and they told me not to use any liquids due to danger of it getting into the cpu needles or something like that. So i looked at the picture and i used a napkin like they did. So far so good as I am running my cpu, lets home nothing bad happens.
u can use alcohal because it evaporates quickly... and leaves no residue...thats about the safest liquid cleaner to use...and it will work best and it removes the oils from your fingers that can contaminate the as5 and decrease efficiency..
Carbuerator cleaner will clean the heatsink in nothing flat. It'll all evaporate and leave absolutely no residue. It also works extremely well at removing those stubborn heat pads. I don't know about putting it on the processor, though. I guess I'd use it if the proc has an IHS but if not, I'd be worried.
Carburerator cleaner is corrossive, had a friend that did that to his video card and killed it.
That's why I wouldn't do it on the chip. Just the heatsink.
1 - 15 of 15 Posts
