I was reading about a tear-down of the Xbox Series X and it looks like thermal putty is used on the new Xbox Series X builds and the Xbox One for the VRAM instead of thermal pads.
In the comments people talked about possible replacements for the thermal putty used in the Xbox Series X and Xbox One:
"Okay so after looking, the closest thing I could find to the blue or green stuff is TG-PP-10 from t-Global on DigiKey. It’s 10 W/mK, so probably a good bit better than the blue or green stuff which is usually 1-6 W/mK. IIRC other manufacturers of this stuff are Bergquist (now Laird?), Henkel, Dow Corning, but t-Global sells the most reasonably priced one for small quantities at just 28$ USD for 50 grams."
The thermal resistance of thermal putty doesn't look as good as you can get with the best thermal pads, but there are variants better than the Phobya 5W/mK thermal tape I bought and it looks a lot easier to apply.
So would it be possible to replace thermal pads with thermal putty? Maybe there's some sort of upper limit on the maximum gap it can fill?
