1 - 10 of 10 Posts
found this while browsing at sidewinder computers today:<br />
<br />
<a href="http://www.sidewindercomputers.com/thhr.html" target="_blank">http://www.sidewindercomputers.com/thhr.html</a><br />
<br />
<br />
<tr>
Thermalright HR-03<br />
<br />
<br />
<img src="http://us.st11.yimg.com/us.st.yimg.com/I/sidewindercomputers_1918_5754132" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<br />
<br />
Product Description & Info<br />
<br />
Definitely a world first and a first for Thermalright, the HR-03 VGA cooler can be run passively or accommodate a 92 mm fan. The HR-03 can be mounted in two ways also, which is a key factor for SLI users. The compatibilities of this VGA cooler have been enhanced to support all the latest cards as well. See the HR-03 for yourself below, we installed it on a BFG 7900 GT-OC, paired with one of our Akasa 92mm Amber series fans.<br />
<br />
* Designed to work fan-less or with a 92mm fan at low RPM for low-noise operation and higher performance<br />
* Proprietary through holes on fins for efficient ventilation and proficient cooling<br />
* 4 innovative designed heat pipes (2 U-shaped and 2 N-shaped heat pipes) for thorough heat distribution across multiple fins<br />
* Two ways of mounting the cooler on video card for best space and configuration management<br />
* Light weight and easy no-tool installation<br />
* Vast compatibility with system cases (ATX & BTX)<br />
* SLI/Crossfire friendly for those serious gaming enthusiasts<br />
* Cosmetically contoured design for that vanity look<br />
<br />
<img src="http://lib.store.yahoo.net/lib/sidewindercomputers/hr032.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://lib.store.yahoo.net/lib/sidewindercomputers/hr031.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<br />
Technical Specifications<br />
<br />
Dimension<br />
<br />
L133 x W156 x H38 mm (heatsink only)<br />
<br />
Weight:<br />
<br />
350g (heatsink only)<br />
<br />
Compatibilities<br />
<br />
ATI:<br />
X1300TD, X1600TD, X1600XT, X1800XL, X1800XT, X1900XT, X1900XTX,X1950,X1900GT<br />
<br />
NVIDIA:<br />
6800, 6800TD, 6800XT ,6800GT ,7800GT,7800GTX ,7600GS ,7600GT ,7900GT ,7900GTX ,7900GS,7950GT<br />
<br />
HR-03 $46.95
</td>
</tr>
</table>
</div><br />
Judging by the 4-heapipe design and 92mm fan compatibility - this looks to be the first TRUE, GOOD air cooling solution (other than the noisy azz stock HSF) for owners of ATI X1800 and X1900 series cards <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
<br />
If I didn't have water cooling, I'd be jumping on this right now!
forget Crossfire or SLI with those things... LOL<br />
<br />
Without fan it might fit though... with fan, no way
as it said on the page - you can flip the entire thing over and use it with the fins pointing down away from the CPU heatsink - i'll bust out ms paint if anyone needs a better explanation
Discussion Starter #5
got mine and mounted a Arctic Cooling 92x25mm fan on there - full load tops out at 48ºC, and it idles at around 35ºC<br />
<br />
WOOT! Thermalright takes the cake again!<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
edit: wow... they block my free hosting URL... come on now OCN
Discussion Starter #6
results from other users:<br />
<br />
<br />
<br />
<tr>
<div>
Originally Posted by <strong>TTP</strong>
</div>
<div style="font-style:italic">Finally got it installed after spending 2 days carefully removing the Arctic Cooler X2 from my Crossfire setup. The thermal adhesive tape used in that heatsink setup on the memory are a ***** to remove. Had to use an xacto knife and slice through the adhesive.<br />
<br />
<img src="http://pws.prserv.net/tpham/P1000329.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000330.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000331.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000333.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000336.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000338.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000339.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000345.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000347.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></div>
</td>
</tr>
</table>
</div><br />
<br />
<tr>
<div>
</div>
<div style="font-style:italic"><img src="http://pws.prserv.net/tpham/P1000348.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000350.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000351.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000352.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000353.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000354.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000355.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000356.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000358.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000366.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></div>
</td>
</tr>
</table>
</div><br />
<br />
<tr>
<div>
</div>
<div style="font-style:italic"><img src="http://pws.prserv.net/tpham/P1000367.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<br />
My previous configuration:<br />
<br />
Arctic Cooling X2 on 2 Sapphire X1900XT 512mb in crossfire mode:<br />
TIM: Arctic Silver Ceramique<br />
idle: 56C<br />
load (2h of Oblivion): 78C<br />
<br />
Thermalright HR03 (passive without fans blowing on it)<br />
TIM: Arctic Silver AS5<br />
idle: 45C<br />
load (2h of Oblivion): 67C <br />
<br />
Thermalright HR03 (with 2 S-Flex 120mm fans blowing from side of case)<br />
idle: 38C<br />
load (2h of Oblivion): 58C<br />
<br />
Pro: this heatsink rocks! Thermalright comes through again. :beer: <br />
<br />
Caveat: You have to double check and make sure you seat the heatsink flat on the GPU. Don't use the square rubber padding that came with the setup. I initially used it and it kept the heatsink from making full contact. When I took it off, it worked perfectly.</div>
</td>
</tr>
</table>
</div><br />
<br />
<br />
<tr>
<div>
</div>
<div style="font-style:italic">Switched the second card to GPU side configuration. Also added a Panaflo 56.7cfm 92x92x25 fan on it.<br />
<br />
idle: 41C<br />
load (after 2h of Oblivion): 56C<br />
<br />
<img src="http://pws.prserv.net/tpham/P1000368-1.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000369-1.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000370-1.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000371-1.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000372-1.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000373-1.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000375.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000376.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></div>
</td>
</tr>
</table>
</div><br />
<br />
<tr>
<div>
</div>
<div style="font-style:italic">some extra heatsink pr0n.. :beer: <br />
<br />
<img src="http://pws.prserv.net/tpham/P1000386.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000387.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000388.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000389.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://pws.prserv.net/tpham/P1000390.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></div>
</td>
</tr>
</table>
</div>
Discussion Starter #7
more:<br />
<br />
<tr>
<div>
Originally Posted by <strong>Jod</strong>
</div>
<div style="font-style:italic">100% a duplicate of XS, sorry...I'm lazy. Here, have a smiley. :beer: <br />
<br />
<font size="5"><font color="Red">Insert blade...saw.</font></font><br />
<img src="http://img.photobucket.com/albums/v212/jodiuh/Thermalright%20HR-03/IMG_1289.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://img.photobucket.com/albums/v212/jodiuh/Thermalright%20HR-03/IMG_1287.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<br />
<font size="5"><font color="Red">So this pretty much explains the cooling differences.</font></font><br />
<img src="http://img.photobucket.com/albums/v212/jodiuh/Thermalright%20HR-03/IMG_1291.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<br />
<font size="5"><font color="Red">The bracket's screws do not stick up enough to get through the card. So I stuck a piece of paper in there to bring them to the top. Def helped to guide the card onto the 4 screws without painting the core with a bunch of paste.</font></font><br />
<img src="http://img.photobucket.com/albums/v212/jodiuh/Thermalright%20HR-03/IMG_1292.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<br />
<font size="5"><font color="Red">I stuck some "lifters" under the other 2 so as to give an accurate idea of the overall heights of these sinks.</font></font><br />
<img src="http://img.photobucket.com/albums/v212/jodiuh/Thermalright%20HR-03/IMG_1294.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://img.photobucket.com/albums/v212/jodiuh/Thermalright%20HR-03/IMG_1295.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<br />
<font size="5"><font color="Red">Only one RAM chip had to be gimped!</font></font><br />
<img src="http://img.photobucket.com/albums/v212/jodiuh/Thermalright%20HR-03/IMG_1298.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<img src="http://img.photobucket.com/albums/v212/jodiuh/Thermalright%20HR-03/IMG_1299.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></div>
</td>
</tr>
</table>
</div><br />
<br />
more crossfire: <img src="http://home.comcast.net/~tonypham/P1000406.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" />
Done deal, I am buying one. <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
Wow, insane. It beats most coolers while not even using a fan... <img src="/images/smilies/eek.gif" border="0" alt="" title="EEK!" class="inlineimg" />
Discussion Starter #10
<tr>
<div>
Originally Posted by <strong>Fishie36</strong>
</div>
<div style="font-style:italic">Wow, insane. It beats most coolers while not even using a fan... <img src="/images/smilies/eek.gif" border="0" alt="" title="EEK!" class="inlineimg" /></div>
</td>
</tr>
</table>
</div><br />
thats thermalright for you <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /><br />
<br />
<br />
<br />
<br />
here's a link to my Omerta Project thread over at XS which includes the HR-03 on my x1900XTX (without image links being blocked)
1 - 10 of 10 Posts
