1 - 6 of 6 Posts
I want to get a venemous x heatsink but all the fans i like are 120mm x 120mm x 38mm.
Apparently the heatsink only comes with clips 2 sets of clips for 120x25mm and 140x25mm fans.
How would i go about fitting a 38mm on? Can i buy something so it fits?
im thinking of getting Delta FFB1212VHE 120mm x 38mm Very Hi-Speed Server Fan or Scythe 120mm x 38mm Ultra Kaze 3000rpm Fan.
Not sure exactly what you mean but do you know if either would fit?
The guy at the store isn't very smart : /
1 - 6 of 6 Posts
