Thermaltake AF0030 Thunderblade 120mm Case Fan
Description:
Max. Air Flow: 70.2 CFM. Max. Air Pressure: 2.41 mm-H2O. Noise: 31.7 dBA. LED Color: Red. Bearing Type: Sleeve. Power Connector: 3-Pins Connector (3 to 4 Pins Adapter Included). Life Expectation: 30,000 Hours 25 degree C. Fan Dimensions: 120 x 120 x 25 mm.
Details:
Description:
Details:
Detail | Value |
Binding | Personal Computers |
Brand | Thermaltake |
Feature | Thermaltake AF0031 Thunderblade 120mm Green LED Cooling Fan. 4x Red LED 120x1200x25 fan. 1800RPM -Low speed fan at minimal noise level. Rated Voltage: 12 V. Started Voltage: less than = 9V. Rated Current: 0.30 A. FAN Speed: 1,800 +/- 10% rpm. |
Label | Thermaltake |
Manufacturer | Thermaltake |
MPN | CAB08113-AF0030 |
Publisher | Thermaltake |
SKU | ARMACA-AF0030B08113 |
Studio | Thermaltake |
Title | Thermaltake AF0030 Thunderblade 120mm Red LED Case Fan 1800RPM-Low Speed Minimal Noise Level |
PartNumber | CAB08113-AF0030 |
ProductGroup | PC Accessory |
ProductTypeName | COMPUTER_COOLING_DEVICE |
