Hey, i'm researching cpu cooler's for the max oc, but the best overall quality as well. (plus 3 year warrenty just because!
This is what i'm working with, and plan to "have" by 2007 february.
*fyi, all prices canadian, all specifics from memoryexpress.com website, easy 2 find*
_____________________________
What i'm asking, is,
Is the Scythe Ninja Plus Rev. B, cpu cooler, or the Thermaltake Big Typhoon 120mm silent heatpipe cooler, better? Which and why?
Thermaltake Big Typhoon 120 Silent Heatpipe Memory Express Link
Scythe Ninja Plus Rev. B Cpu Cooler Memory Express Link
Between the two, which would run best?
I'm in a basement, well the computer's are. Big room, cement flooring. In western canada.
Average temps are anywhere from 10c - 20c. Occasional 23-25 celcius in the summer. While the main floor + 2nd floor are 10 degree's warmer in the summer and the winter.
I'm looking to oc the hell out of the e6300 eventually. (I'll eventually replace the 2x512mb ram sticks with 4x 1gb sticks, eventually, install total 6x hd's, sli pci express, mb the r600's or similar, etc...X-fi fatality as well, lots of cables going around).
And another question, re: Scythe ninja, can I mount on it's fan, a "grill" ? (Easier to get cables around it, without blocking it, or getting sucked into it, etc.
Thanks!
Le_Loup
$ 219.95 Intel Core 2 duo E6300 Processor $ 214.95 Kingston HyperX 1GB PC2-6400 Dual Channel DDR2 Kit (2 x 512MB) $ 119.95 Western Digital 320GB Caviar SE16 7200rpm SATA II w/ 16MB Cache $ 299.95 eVGA nForce 680i SLI w/ DualDDR2 1200, 7.1 Audio, Dual GB Lan, 1394, Dual PCI-E x16 SLI $ 169.95 OCZ 700W GameXStream Power Supply w/ Quad +12V = $ 1024.75 + $ 159.95 Antec P180B Advanced Super Mid Tower, Black = $ 1184.70 |
Thanks!
Le_Loup
