1 - 1 of 1 Posts
Thermaltake BigWater A80 All-In-One LCS Water Cooling System Intel Socket 2011 Ready - CLW0214
Description:
Thermaltake BigWater name is known to many enthusiast users for offering liquid cooling solutions for many years and here we have the first offering of a completely sealed maintenance free solution the BigWater A80. By maintenance free means all that is needed is to mount the radiator then the block/pump assembly as it is pre-filled with the required coolant and all components are installed. With universal socket compatibility this cooler fits a full range of processor needs from AMD (AM2/AM2+/AM3/FM1) to Intel (775/1155/1156/1366/2011) this cooler even offers correct mounting for the yet to be released AMD socket FM1 and Intel 2011. Includes a single variable fan to allow for PWM control by the systems motherboard or user via the included VR knob of fan speed to provide cooling as needed and silence when you want it.
Details:
DetailValue
BindingPersonal Computers
BrandThermaltake
EAN0841163042199
FeatureAll in one solution- Maintenance free no refilling or checking fluid level as the unit comes sealed and only needs to be mounted and plugged in for worry free long term operation.
Ideal thermal mechanical design means that the BigWater A80 powerful fan effectively removes heat from the system through the radiator out the rear of the case
Universal Socket compatibility supports all recent sockets from AMD (AM2/AM2+/AM3/FM1) and Intel (775/1155/1156/1366/2011) and even supports the yet to be released 2011 and FM1 socket to cover future upgrade needs.
Proprietary duct included to ensure support for all computer cases with an available 12CM rear fan mount.
Ideal alternative cooler to maintain high-level of cooling power found on traditional air-cooled solutions.
LabelThermaltake
ManufacturerThermaltake
ModelCLW0214
MPNCLW0214
PublisherThermaltake
SKU01AFIF-000
StudioThermaltake
TitleThermaltake BigWater A80 All-In-One LCS Water Cooling System Intel Socket 2011 Ready - CLW0214
UPC841163042199
Warranty2 years
CatalogNumberList - CatalogNumberListElementCLW0214
Item Height6 inches
Item Length12.5 inches
Item Width7.5 inches
NumberOfItems1
Package Height1 inches
Package Length1 inches
Package Weight1 pounds
Package Width1 inches
PackageQuantity1
PartNumberCLW0214
ProductGroupCE
ProductTypeNameVIDEO_CARD
UPCList - UPCListElement841163042199
Item Weight3.5 pounds
1 - 1 of 1 Posts
