1 - 7 of 7 Posts
I know people have this case. Despite the ugly marketing photos this case is really nice. I love it, super efficient and quiet cooling, a strong contender and alternate to the HAF. Threads on t his case are few and fare between though.
Who has this case and what have you done with it? I am highly considering installing an overkill extremely large radiator in the top, however I'm hesitant to take the initial plunge without seeing what other people have built. They claim a double 200mm radiator should fit easily. Anyone have photos? What rads did you use?
Discussion Starter · #2 ·
Really? No one has this case? I know I've seen a few on here. Really surprised, because I think this case is FAR superior to the overrated HAF 932. (This should stir it up
It is INDEED much nicer than the HAF 932. That poor case is terribly ugly.
As for the radiator, I think you might be able to fit an XSPC RS240 on the top if yourmotherboard doesn't have huge heatsinks (which it doesn't, because it's the same as mine
And you can fit a 120 rad on the rear 120mm fan too!
I have this case but i haven't done anything with it yet ,and your right ! it looks way better in person. one thing that kinda shocked me was the size of the case . I wasn't expecting it to be so huge lol
440700338338
This is what I did to my chaser. Watercooled and overclocked to 4 Ghz, ill prob OC more after i install the 240mm rad on top in about a month. anyway enjoy!
What RAD are you using currently then?
I am pretty sure a 240mm rad will fit fine depending on how thick it is. If it's a thin one I think you can even store it in the top and use push fans underneat it.
I also have it but I am on aircooling. It works really well on air.
@Mountaindew Kid: how did you link up your extra colourchange fans so that you can make the LEDs work?
The extra fans arent colour-change, they are just 200mm coolermaster megaflows which come in default blue and red, i bought blue and just connected them up via molex and the LEDs worked.
1 - 7 of 7 Posts
