Hi guys, I need a horizontal m/b setup chasis for my next project. I was deciding between MountainMods and Caselabs S8. However the premium price of these two really put me into an unpleasant budget balancing dilemma.
I think it's today or yesterday, Thermaltake just launched their Core series chasis. The Core X9 is ****** huge. 640 mm of depth!!! supports dual 480 rads on top AND on two sides!! Fully modular and the most important thing is, it only sells for $169??!! ****** Christ...I just had to preorder it...
On specs page, it states that the material of the chasis is SPCC. A quick google shows that SPCC is a standard for cold rolled steel sheets in Japan. I have absolutely no idea how does SPCC compare to Aluminium when it comes to strength and weight. Can overclock gurus share some insights and ideas on Thermaltake chasis quality?
Thank you
Thank you
