1 - 9 of 9 Posts
Originally Posted by xUp1nSmokex View Post
I can get the Frio for $40. Is there something else I should get or is that a good buy?
if your budget isnt higher then $40 then get the frio.
Retired Reviewer
the frio's a great heatsink. i've found it comparable to my megahalems, and for $40 it's an absolute steal, assuming the fans are bundled with it as well. go for it!
I'm using the frio on my i5 750 getting temps of 80c @ 4ghz / 1.36v on load. If you purchase this cooler PM me your temps cause i'm interested to compare.
Retired Reviewer
Looks interesting. What's your bclk? Vtt? Ambient?
Discussion Starter #9
I decided to pull the trigger on the Frio for 40 bucks shipped. Thanks guys and Rickoles I'll let you know.
1 - 9 of 9 Posts
