I have an expectation when I decided using custom watercooling on my intel x299 system using i7 7820x OC'ed to 4.7Ghz
Before I use this thermaltake Pacific RL360 D5 I use a Corsair H115i and maksimum load temp while Stressed using Realbench or Prime is about 83-86 c after 30 minutes
So, I change to this thermaltake LCS, but I really dissapointed, 5-10 second after I run Realbench the temp skyrocketing to 100-105 C and I got BSOD, I have check everythings, pump work, Waterblock sit correctly
What the hell is happening here???
is the thermaltake W1 waterblock bad? or some faulty?
I really frustrated here
need some advice , please
