1 - 6 of 6 Posts
I am disappointed in Thermaltake Support. A Big Typhoon I bought had two standoffs with bad threads. Their response was that I would have to get an RMA, and return the parts to get replacements. Poor.
whats poor about that? sounds like they would get you what you need? what more can you ask for?
well how else are you gonna get it sorted <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink"><br><br>
ohh noooo there replacing the broken parts!
Well what else do you expect. You could just be lying so they have to be sure.
I don't know where you purchased your BT from, but this is why I try to buy stuff from local stores like Tiger or Fry's as opposed to mail-order.<br><br>
If something's not right, you can take it back within 30 days, and they'll usually make it right.<br><br>
I can't tell you how awesome the tech people at Tiger were for me when I purchased not one but two bad boards. Not only did they troubleshoot the problem(s), they did the actual replacement while I stood there and picked my #*^!!!.<br><br>
Good luck!!!<br><br>
BTW, pull the stock fan and replace it with a 110 cfm silverstone.
Discussion Starter #6
An RMA for two standoffs seems kind of silly. Must be worth a max of 50 cents. Hardly worth lying about.
1 - 6 of 6 Posts
