1 - 10 of 10 Posts
Well, installed it and I am gettin the same temps I did with my old heatsink/fan 40/50. Put As5 on there 2 bb drops spread it around, tightened it on there real good. 2 90mm 85cmf fans turned at half speed, full speed makes no difference. Do I have to wait a couple days for the temp to drop or what? Otherwise ***? These temps are according to Speed Fan, but even if it was lying, that means my other heatsink was just as good.
Originally Posted by OzziKing
This was my old one.
http://www.newegg.com/app/ViewProduc...150-041&depa=0
you would think the tower would blow it away...
I had my "silent tower" do the same thing. it had to much paste on it. I removed the cooler....cleaned off the cooler ONLY.....re-spread the grease left on the cpu and re-installed the cooler.....temps dropped 8 degrees within 24hrs....also make sure all 4 corners are EXCATLY the same height. that cooler should kill the other one. i get load temps of 42 at stock speeds....48-49 at 25%oc at 3.75 with vcore at 1.55.
Discussion Starter · #8 ·
well, damn, took everything apart put barely any on it at all and smeared it all over the surface about paper width and after an hour of work only a couple degree decrease, i guess ill wait a couple days for it to "cure". Im sick im tired and im fustrated im goin to bed.
Originally Posted by aznchowboy650
try getting another program instead of speed and and how are ur fans oriented as in how are they blowing
I checked it in BIOS same temps. <----case fan <-----90mm on tower ----(tower)---- <----- 90mm on tower
Push pull config blowing out the back of my case.
1 - 10 of 10 Posts
